Results 1 to 20 of 20
Thread: LED Lights
    Dec 2016
    Iowa
    Default LED Lights
    Is there a go-to brand that is most commonly used in accenting Spyder RT Limiteds that is reliably?
    2016 RT Limited , Black
    Invalid Emails
    Feb 2016
    Dublin, OH
    Hi Tyris! I'm Cindy from Tricled.
    Our company has been the leader of custom manufacturer of aftermarket led lights for Spyder and other off rad vehicles for the past 6 years.. We are also vendor here in Spyderlovers.
    If you need any help or questions on leds, you can contact me here via PM.
    Houston
    Also check out Spyderpops. Between TricLED and Spyderpops, they have you covered for accent lighting. They both carry some different products from each other.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    These two GREAT vendors will have all of your needs covered!
    Aug 2015
    Canton, Ohio
    [QUOTE=Cindy-TricLED;1213139]Hi Tyris! I'm Cindy from Tricled.
    And they give great support on all of thier products too!
    Joe
    Jul 2011
    Morgantown, WV
    You can't go wrong with Tricled!
    Mar 2013
    Marion, Arkansas
    Harvey at Spyderpops is also an excellent vendor and supplier of LED lights. I had Spyderpops install my LED headlights and foglights at an Spyder event. And he stands behind has products. I had a problem with my light bumpskid and he sent me replacement LED's , no questions asked.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Both of the vendors that have been mentioned so far, offer GREAT products, and even better customer service!
    Vermont
    Tyris,
    I have bought a lot of led's( lights)/and accessories from TRIC-LED for my 2014RTS-SE6, they have excellent customer service, and excellent selection of lights/accessories to choose from.
    I have also bought led's(lights) from Spyderpops. Spyderpops has also been at Spyderfest( Springfield, MO) as a vender.
    Also, check other venders on this site, on the "Homepage". Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Active Member rick_w's Avatar
    May 2013
    NE Ohio, Madison
    We sell Spyder LED Lighting from several different manufacturers. We have had very good luck with TricLed products. The warranty and support we get is superior.
    The LED bulbs available are pretty cool and a fairly easy install. If you have not converted I strongly suggest doing it.
    I put together a video for the RT LED Headlight Bulb install and also another video for the RT LED Foglight Bulb install. Gives you an idea of what you have to do plus how the LED's look lit up.
    LED Headlights or Foglight Bulbs, Can Am Spyder RT (pr)
    Rick
    Spyder Lovers Vendor
    Value-Accessories
    Dec 2016
    Iowa
    Will check out vendors here, thanks. I didn't realize there were laws about lights (should have) so now have to figure out what is allowed in Iowa. Thanks for the responses. Dan
    Blazing Member fastfraser's Avatar
    Feb 2009
    Orangeville, Canada
    I agree TricLED is a great company that stands behind it's products ! Also check out Custom Dynamics as they also carry a lot of LEDs for the Spyder.
    Happy Owner
    May 2015
    United States
    Can any one with Lamonster led headlights chime in and state if moisture gets into the lense since cutting the back of the housing is needed to install them.
    I just purchased a set of LEDs from Lamonster but I just read on the tricled site that cutting into the housing will let moisture in and to stay away from that type of install.
    Thanks for any input.
    Aug 2015
    Canton, Ohio
    Default Value Accessories
    Hey, I have used Tricled and Value Accessories for lights and more, either one will provide you with good value, great products and outstanding customer support. Value Accessories has actually sold me some of my SpyderPops and Tricled parts, they offer good consulting with the product.
    Joe
    Default WELLLLLLLLLLLLLLLL
    Quote Originally Posted by beefybudds View Post
    Although I don't have the LED's, I did drill four 1/4 inch holes ( 2 on top - 2 on bottom of both covers ) for air circulation. Which are open and allow considerably more water access to the bulb than anything Lamont is doing with the wire etc...... and I have had no issues with water ....... Mike
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    I installed Lamont's lights on several bikes with no problems. And a little caulking will fix any concerns.
    2022 F3 Limited , Monolith Black / Dark
    May 2015
    United States
    Quote Originally Posted by DriftersWay View Post
    Thanks for the reply.
    I wouldn't think Lamonster would advise us to do harm to our bikes but I just needed to confirm with other members.
    Central Valley, Ca
    Default Back Brake Blinkers
    Quote Originally Posted by Cindy-TricLED View Post
    Do you have the "Back Brake Blinkers" for a F3-S model? I was looking at your site, but I couldn't find it.
    Bossier LoUiSiAna
    Default LED Lights
    Quote Originally Posted by ussoldier View Post
    Rivico has some universal mounts called S.O.M.A lights. (Stay Off My A**)
    https://rivcoproducts.com/catalogsearch/result/?q=Soma
    the small led's modulate when brake is lit the long strips are Tricled both are lit with just the tail lights.
    Invalid Emails
    Feb 2016
    Dublin, OH
    Someone already answered your question, sorry I just saw this.
    We don't have brake flasher modulator for F3.
    Only the run brake turn led for the center.
