Results 1 to 11 of 11
    Polk City, FL
    Default Flying 3'x5' Flags from a 2016 Can-Am Spyder RT S with Can-Am trailer hitch installed
    I would like to be able to fly two (2) 3'x5' flags from my new (of 10 days!) RT-S when participating in Patriot Guard Rider missions. I had the trailer hitch installed in the hope that I could find a bracket to use with the hitch in order to fly the two flags. I have looked at what info I could find on this site, but nothing works. Short of having a bracket custom made, does anyone have any info about such a bracket? Thanks in advance for your help!
    Apr 2014
    Beloit Kansas
    Except custom made ? Guess that leaves me out.
    Panama City Beach, FL
    RIVCO makes a product that works. I have a single flag on my 2015 RT. You have up to three flags on this unit
    https://rivcoproducts.com/shop-by-ca...ag-holder.html
    Dec 2014
    United States
    Default Flag Holder
    Try going to Rivcoproducts.com and look for PF1000. This should work for you with the hitch. I had one on my Victory vision and it worked fine.
    Bossier LoUiSiAna
    I can understand 1 large flag but two is asking a lot of any bracket
    All my PGR buds with large flags have custom poles of PVC with whatever clamp or bracket they need for their bike. & only for the short escort runs under 30mph. Its ez enough to DIY one you just need to inspect & chat with those that have them, maybe they have an old one that will work better for you¿ Nothing wrong with the smaller bike flag, its a procession not a parade
    However seal teal did tackle this possibly with the universal hitch mount
    http://www.sealcreativeconcepts.com
    Fyi i emailed him & this was reply:
    I've taken that item off my website until I can make it stronger. Two lg. flags put tremendous pressure of a mount and can actually tear the steel plate holding the tubes. Will address the problem next Spring. I appreciate the heads-up.
    Ride in comfort
    Very Active Member WA5VHU's Avatar
    Cooper, TX
    I use an Amateur Radio mobile whip that is up on a fiberglass stick to get the antenna higher for better range, which would be about like a flag. It was to be temporary for one event but it stayed on the hitch for quite a while. It doesn't look all that great but it was a temporary measure, if you wanted to make one better looking you could.
    I used a square u-bolt, some aluminum L-bracket material and tubing and a couple of hose clamps.
    Current:
    2016 Honda CTX700 DCT ABS (faring model)
    Kip Moto SherpaX Cargo Trailer
    Wife Has:
    2014 Can-Am Spyder RT Limited
    2016 Lees-ure Lite Camping Trailer
    Previous:
    2013 Can-Am Spyder RS SE5, zoom-zoom!
    2011 Can-Am Spyder RT-S SE5, Foot Burner - Gasoline Boiling Stinker - Gas Tank Vacuum Puller
    May 2016
    Grand Prairie, TX
    Try this guy/ He makes them for CAM AM's. Up to 3 flags and will sell the poles. I have seen one and I looks really nice.
    http://jandjflagmounts.com/index.html
    Good luck
    Jun 2013
    Quote Originally Posted by rwebb98 View Post
    Good luck
    That link doesn't work - try this one http://www.jandjflagmounts.com/index.htm
    Mar 2012
    Beaverton, Oregon
    I hade a custom made adapter and used the Rivco flag holder for 1 flag. I added Stainless steel cabling that prevents the flag from bending back at speed.
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Invalid Emails
    May 2010
    Chelan, WA .. the dry side!!
    Default Sealfloorboards....
    Quote Originally Posted by Cando's Ryde View Post
    Check with John Anderson owner, designer of Sealfloorboards....he had designed what you want and sold a couple years ago...He is a site sponsor..Merry Christmas
    Mar 2012
    Beaverton, Oregon
    I think I read that John has removed the dual flag holder from sale because the material could fail but I am not sure. Check with him, he makes quality products.
