Results 1 to 25 of 26
Thread: Grips to small
    Jul 2016
    Ranlo N. C.
    Default Grips to small
    I have the 2016 rts with heated handles and my hands get cramped with longer rides and old age. Are there bigger grips that can be slipped on with not to much DIY $
    Sent from my SAMSUNG-SM-T337A using Tapatalk
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    Get some grip puppies. They are reasonably priced and easy to slip on over your stock grips. Spyder pops has them.
    Sent from my VS990 using Tapatalk
    14 RT-S , Stock Large brake pedal White Pearl
    Invalid Emails
    Oct 2015
    morgantown west virginia
    I got a set of leather grip wraps off of ebay for about $20.00. work well and no sticky either.
    Feb 2012
    Spring City,Utah
    If you want some really pretty ones, Kuryakin(sp) has some nice clamp ons that go over the Goldwing heated grips. If you have an SE5 there is some modification for clearance but not bad. Do a search for the threads on this. I did it and the heated grips still shine thru,tho it takes a little longer.
    check this out http://www.kuryakyn.com/products/275/iso174-grips
    see post #12
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Another vote here for the Grip Puppies!
    Apr 2013
    Somersworth, NH
    Grip Puppies! Easy on the hands and the heated grips are still effective.
    2016 RT-S Special , 2 tone black
    Nov 2013
    Oro Valley Arizona
    Ya trying to tell us ya got big hands and uhh---
    Loosen up your grip will do wonders for your problem. Your handle bars are not the same as bull dogging a
    steer with horns. You do not need to have a white knuckle grip. It will stop the cramps and smooth out
    your steering. Try it--you'll liked it.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Apr 2011
    GREENVILLE, SC
    Default $6
    $6 @ LOWE's.....
    para-cord....
    i wrapped it from inside to the far end of the grips...
    added just enough in diameter to make things a lot more comfortable...
    Dan P
    SPYD3R
    Aug 2015
    Canton, Ohio
    Default Tricled foam grips
    Go to Tricled, a site sponsor, they have an outstanding foam grip. I think they are $12 or two sets for $20. They work well for what u wanted, does not affect heat, cooler in summer, and easy on and off. They seem to last long and work perfectly.
    Joe
    May 2011
    Round Rock, TX
    I second Tricleds. 5 minutes in the parking lot with hand sanitizer for lubricant and they're done. Hands don't sweat in summer but warmers still work great in the winter. Dense, open cell foam works great ...
    thehawk.
    In theory, there is no difference between theory and practice ... in practice, however, that's just a theory.
    Bryant, Arkansas
    Go to Spyderpops (site Sponsor) he has the best foam grips.
    Cruzr Joe
    May 2013
    Stanton, ca
    What I used.....
    Bob
    Jul 2016
    Ranlo N. C.
    Quote Originally Posted by jaherbst View Post
    Jack
    Yes for sure but old Arthritis kicks in about 50 miles out from go. #rideforfunnotpain.😆
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Sep 2014
    USA
    The foam grips worked fine for me as others have stated above and it was the right price. I even bought my Dad a set
    Nov 2016
    Hummelstown.Pa.
    I used the Grip puppies also lubed them up with Dawn and they slipped right on
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Quote Originally Posted by SPYD3R View Post
    $6 @ LOWE's.....
    para-cord....
    Dan P
    SPYD3R
    Looks great.. How did you fasten the ends of the cord??
    2022 F3 Limited , Monolith Black / Dark
    Active Member rick_w's Avatar
    May 2013
    NE Ohio, Madison
    Quote Originally Posted by Ctider07 View Post
    The answer depends on how much work you want to do and how much you want to spend.
    The cheapest and easiest way to go is Grab On Grips Grip Covers (pr) $12.50. We can not bring enough of them when we go to Spyder Events. I actually use a set on our HD Ultra Classic.
    On our own Spyder RT I installed the
    Kuryakyn ISO Grips for use with OEM Heated Grips. GL1800 06+ & F6B Models.
    Will work on Can-Am Rt Heated Grips with modifications.
    This will require some modifications but for the money a must have for anyone wanting comfort.
    Rick
    Spyder Lovers Vendor
    Value-Accessories
    Mar 2015
    Advance, NC
    Yup, Grip Puppies. Yes, use hair spray to install them.
    Sep 2012
    Junction City, KS, USA
    Grip puppies. They're available from several SL sponsors. If you come to Spyderfest, you may get some as a prize at one of the host hotel parties.
    Jul 2016
    Ranlo N. C.
    Danbury Connecticut
    I like the foam grips as others have recommended.
    But if you ride in the winter, the foam grips DO affect the heat. Running the heat on high warms the hand grips but not as much as it would if there were no foam grips.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Jul 2016
    Ranlo N. C.
    Jul 2016
    Ranlo N. C.
    Did mine and thanks for idea. Ride safe and often.
    Jan 2013
    San Diego area
    Default Small Grips
    I got the grip puppies and love them
    Loving the RYDE
    Aug 2015
    Canton, Ohio
    Good decision, congrats!
    Joe
