Results 1 to 19 of 19
    Jan 2013
    lancater ohio
    Default Spyder in the snow!!
    We got a little snow when I was athinking work today so the commute home was very fun20161213_155805.jpg
    Jan 2016
    Rochester,NY
    Does it even move in snow?
    https://youtu.be/wCXPtvdJzjI
    Maybe not when you're going out of your way to make your Spyder do donuts like Shawn was in that particular ^ vid!!
    But it's just like ryding in the rain - you'll be fine if you take appropriate care; ryde sensibly within your capabilities & comfort zone; ryde at a sensible speed for the conditions; & the snow or rain isn't really all that heavy, deep, or covering black ice!! Always ryde to the conditions & you shouldn't ever have too much in the way of hassles!
    Active Member CharlieIndia's Avatar
    May 2011
    Washington Pa.
    Jan 2013
    lancater ohio
    I was amazed at how will it did on the 50 mile trip from work!!
    Default Yikes...!!
    That was fun at the least....Well once you saw things were not as bad as you thought...
    Yep, get some good tires on it & ryde sensibly, & fresh dry snow on a Spyder can be an absobloominfantastic ball, can't it?!? Not that we see all that much of it here in Oz, but those of us with Spyders who've lived &/or worked above the snowline & made the effort to ryde whenever we can really don't take all that long to learn to appreciate the extra stability & downright FUN the Y factor can add!
    My GS would not go through that sticky slushy stuff. The back wheel just spun for me on the slightest hill. Glad you had an okay ride back.
    Sep 2014
    USA
    Holey crap 50 miles home. I would have been in pucker up mode.
    Lemme guess...... errmmm, Kenda tires!
    Very Active Member JimVonBaden's Avatar
    NoVA
    I'm glad I am not the only one!
    Jim
    2013 ST-S (wife's)
    2015 BMW R1200GS (mine)
    1981 Yamaha XS400 Scrambler Custom (mine)
    Very Active Member bronzeflex42's Avatar
    Sep 2014
    Sandersville, GA
    wow
    2012 Spyder RT Limited Lava Bronze (Psalm 27:1;Luke 12:4,5)
    It looks as if you had fun!
    How deep was the snow?
    Of course. Is there another brand out there?
    Yep - HEAPS of brands & tires in sizes that work, treads patterns & compounds that perform, beads that match, higher load & speed ratings, consistency of construction that far exceeds the dubious quality of the Kenda rubbish, & Waaaayy better traction, ride, handling, tread life, & even noise levels than you'll get from the Kenda's!
    Originally Posted by akspyderman Of course. Is there another brand out there? "
    "From Peter A:
    Yep - HEAPS of brands & tires in sizes that work, treads patterns & compounds that perform, beads that match, higher load & speed ratings, consistency of construction that far exceeds the dubious quality of the Kenda rubbish, & Waaaayy better traction, ride, handling, tread life, & even noise levels than you'll get from the Kenda's! "
    AK:
    Unfortunately, it's a moot issue here. The dealer will only install OEM Kendas and preaches the BRP line on that subject. I don't want someone messing with my who does not know how to properly remove the rear wheel. Fronts no issue--but I get 20K plus out of the Kendas. Held hostage by the dealer for sure on this one.
    Invalid Emails
    Feb 2016
    Dublin, OH
    Go - Go RT snow!
    Active Member kenfromhv's Avatar
    May 2014
    SW Laurel Mtns PA
    Party Animal - fun to go downhill
    Jan 2013
    lancater ohio
    In Columbus it was just wet roads but when I got close to Lancaster the city I live in it was up to 1 in of snow.
