Broken spring - F3L
I broke a spring on the bottom of my spyder this morning and am not sure what it came from. My bike drags a little when I put it in my storage shed and when I pull in i usually get off the seat and put my feel on the ramp prior to pulling all the way in. I was going to back it in yesterday which normally I don't do and it drug a lot before I caught it and I turned it around and pulled in like I normally do. This morning when I backed out I noticed a broken spring ... which I am sure is from the constant rub on the bottom and probably aggravated more by trying to back in yesterday.
I have mentioned the issue of the ramp not being right but it never got fixed. Einstein is now going to fix the ramp after I have griped about it for most of the afternoon but I still have to figure out the spring problem. The bike goes forward and backwards OK but I didn't drive it anywhere today because I am not sure what impact that missing spring might have.
Can someone post a picture of this spring installed or tell me what it connects to?
Love my Spyders
2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
2014 RTS Circuit Yellow purchased 3/2/2018
2020 RTL Petrol Blue purchased 1/27/2023
Girls on Spyders #3195
No more 2 wheels
2020 RTL , Lamonster floor board riser Petrol Blue
I have a F3 but that sure looks like a exhaust spring.
Looking underneath those are the only springs I see on mine.
Good luck.
The exhaust springs are lower than the exhaust, so you have to be careful when you put your lift under that you don't catch them, so I would imagine that taking them over the ramp wouldn't do them any good. I'm not home at the moment but I'll post a pic asap.
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
F3-L exhaust
IMG_1076.jpgI think you'll find your bottom one missing
HeliBars Handlebars
Kenda Kanine rear.
Ozzie Ozzie Ozzie
Originally Posted by Peteoz
... I think you'll find your bottom one missing
You've probably got a bit of a ding in the flared section of pipe where the spring was pushed onto it hard enough to break, & may also have broken the gasket which that flare covers!! I believe there are 'better' (? cheaper?) gaskets & springs in the correct size available if you specify they are for a Honda - worth a shot, anyway!
Thanks!
Love my Spyders
No more 2 wheels
