Alwasy get wet when it rains
For some reason, when I am on the F3 and its raining, the water gets up underneath my rain jacket and over the rain pants. I thought to get a one piece suit, but then I can't use my heated vest because the power cable, even with an extension, is too short. What do you people do?
I've had a problem of rain getting inside my jacket and figured out I didn't have it closed up near my chin.
Simple answer, don't ride in the rain. Problem solved.
SPYD3R FLOOR/SPLASH BORDZ
EASY SOLUTION.......
make yourself a pair of these FLOOR BORDZ.... and the water will exits behind your feet....
you'll notice that the bordz extended under the SPYD3R along the splash guard behind the front fenders... this keeps the water running under, versus up onto your feet & pant legs.... that's why i designed them that way, to stay as dry as possible...
good luck, and let us know how yours came out....
SPYD3R
![Quote](images/misc/quote_icon.png) Originally Posted by Sam Mac
Simple answer, don't ride in the rain. Problem solved. ![Roflblack](images/smilies/roflblack.gif)
Ozzie Ozzie Ozzie
![Quote](images/misc/quote_icon.png) Originally Posted by Rogue Hawk
For some reason, when I am on the F3 and its raining, the water gets up underneath my rain jacket and over the rain pants.....
Where do you get wet; all around your waist or just in the front??
I ask, because I bought a new set of rain gear at the beginning of our last winter (Late May/early June here!) & the over-pants had thoughtfully provided 'pocket openings' each side closed with a velcro tab in the middle that'd still let you get at your jeans pockets when you were wearing the rain gear. Fair enough I thought, until the first heavy rain revealed that when I sat on my RT, both of the openings either side of the velcro tab gaped open & funnelled water running off my jacket straight thru & into my crotch!! ![yikes](images/smilies/22yikes.gif)
Getting to your destination warm & dry everywhere but your crotch is NOT a great feeling!! And if you ryde long enough, the more water that runs in means the wet spot extends down between your legs & eventually pools where you sit, so it's more'n just a tad uncomfortable & if it bothers you that way, the wet patch once you stop & strip off your rain gear can be very embarrassing!! ![shocked](images/smilies/shocked.gif)
So I sewed the pockets shut & 'seam sealed' the former openings - no more problem now!! But I will watch out for that little trap when I next replace my rain gear, thoughtful as it may have been intended!! ![Stick Out Tongue](images/smilies/tongue.png)
With your problem, do you think it'd help velcro-ing the inside of your jacket to the top of the rain pants??
![Quote](images/misc/quote_icon.png) Originally Posted by Peter Aawen
With your problem, do you think it'd help velcro-ing the inside of your jacket to the top of the rain pants?? ![don't know](images/smilies/shrug.gif)
The water come up from the bottom, then underneath the rain jacket, up over the rain pants, and wets my stomach. The rain jacket has pulls on the side to tighten it around my waist, but it does not help.
used to get wet when it rained
I too used to get wet when it rained; the expectation from rain gear is that you will stay DRY!!! Unfortunately unless you go to the upper level of riding gear your expectations are not going to be met consistently.
If you want to stay dry then you have to spend the $$'s on gear that is water impermeable and fits properly or that won't happen.
Talk with Ron about first gears offerings or speak with Joe or Ann Meyer about what they use. Another good source would most likely be Murphy Brown.
The high mileage riders know what it takes to be DRY and comfortable when they travel. If you are really serious about staying dry when you ride speak with them and they will point you in the right direction to do so!!! JMO FWIW
2018 F3-T
![](https://www.spyderlovers.com/forums/maps/map.png?states=ME.NH.VT.NY.PA.IN.MI.IL.WI.MN.ND.SD.NE.KS.OK.CO.WY.MT.ID.WA.OR.CA.NV.UT.AZ.NM.TX.TN.KY.OH.WV.IA.MO.AR.VA.NC.SC)
This perfectly describes the need for a one-piece rainsuit...
Reason #57
Reason #57 why NOT to trade my RT for an F3. Before this thread I only had 56 reasons.
![Big Grin](images/smilies/biggrin.png)
I'd LOVE to see, one through fifty-six...
Ouch !
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
Should I have added the caveat: "Be sure to find one that fits you properly."? ![don't know](images/smilies/shrug.gif)
I thought that was assumed parameter...
Hahaha.....I've tried, Bob......believe me, I've tried
HeliBars Handlebars
Kenda Kanine rear.
One piece
Aerostich will alter their one piece suites. While I have not had any of their garments altered, I have used their jackets and pants. I can attest that they have been waterproof, breathable, and off great protection (depending on the style ordered).
check out their catalog on line. Good luck
Never been an issue
And I have been in some heavy, sustained rains while traveling at safe, for conditions, hiway speed. Not sure what I do diff. My rain pants are big so I end up with the waist about mid chest...my rain coat over that...all zipped in tight. Jacket is butt length ..boots are waterproof and my pants have the elastic stirrup that holds them down. I wear my normal ryding gloves (weight dependent on weather) with my Aerostitch 1000% waterproof covers.. I was "warned" that this could be a down side to the F3..but so far so good..I say 1000% on the Aerostitch because keeping dry gloves was my biggest challenge and finally accepted that no glove was going to be waterproof (to many seams)...but those covers are the BEST. Oh yea my rain gear is Frogg Toggs motorcycle specific ..had Can Am before...pants failed and still have the jacket for a back up..
