Results 1 to 14 of 14
    Oct 2007
    Question Silencer too loud
    Thinking of changing the Akrapovic Straight Shot Silencer back to the stock one on my F3S because it is too loud. Has anyone have experience with the sound level between the two silencers, is the stock one quieter?
    May 2011
    Karaka NZ
    The stock one is very quiet, until you get up in the rev range then it has a little bit of a bark.
    I have the Akrapovic from an RT Triple, it has a very nice tone, a little deeper than the straight shot,
    and it is also longer, so the noise leaves the muffler closer to the rear of the Spyder.
    Not a great pic below, but you should be able to see the difference in length.
    2015 F3 , Black with Blue Graphics
    Oct 2007
    Quote Originally Posted by Colin View Post
    Thanks for the info Colin. I will definitely change it, don't want the dog to get hearing damage when she come with me.
    Jun 2010
    Las Vegas
    I can't hear anything anymore
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Waddya say?
    Canada
    Quote Originally Posted by doghead View Post
    I go deaf with Akrapovic Straight Shot and cat delete pipe
    Jan 2013
    Glendale AZ (formerly Oz, Albury NSW)
    Default It's Not The Akrapovic
    Someone removed the catalytic converter. Wrong...
    We have the Aker with cat (the way it is meant to be) and it is a beautiful, muted sound that is so superior to standard.
    Kennesaw, GA (Atlanta Area)
    Quote Originally Posted by Trevor G View Post
    Do you see a performance difference or a mpg difference with the cat delete and Aker silencer?
    NorCal - Northbay
    Something is amiss then. was the primary muffler removed as well? I have the Akra SSS as well but kept the primary muffler in place and absolutely love the sound. Def more aggressive than stock but nowhere near too loud!
    Chuck
    Oct 2007
    It was installed by the dealer so it should be ok. The cat is still there so it is only a straight swap with the stock one. I am not worrying about what sound it makes as long as it is quieter.
    Oct 2007
    Quote Originally Posted by hypurone View Post
    Everything is standard Can-am parts. It was installed by the dealer when I bought it new. As I said before I want it to be quieter so the dog is comfortable. I got the stock silencer here so when I swap it I can compare. If the sound level is the same I can always change it back.
    NorCal - Northbay
    What I am referring to is the "primary" muffler (the larger shiny thing underneath) to which the secondary muffler (the Akrapovic) attaches. If the primary was removed and a bypass pipe installed, it will be a LOT louder than just the Akrapovic by itself....
    Chuck
    Oct 2007
    Yes, the larger shiny thing is still underneath, there is no bypass pipe.
    NorCal - Northbay
    Then I'm afraid your only option is to go back to the stock unit as there are no baffles made for the Akra....
    Chuck
