Mufflers/cats
Has anyone ran a GPR muffler with cat. on? Have2015RT S SE6 and like listening to music when riding, but would like a little louder exhaust. Want to leave cat ON for warranty reasons. GPR is Italian made, straightforward swap, street legal system,, all in kit. Would like to know how loud they are with cat or without. Thanks all for replies!! Niterider
2015 RTS , Stock Black Rubber Pearl White
How CAT removal effects the warranty
There's a lot of misunderstanding about how the CAT removal effects your warranty. For the record, BRP will not void your warranty if you replace the CAT with the bypass pipe. However, they do reserve the right to deny a particular claim that they consider was caused as a result of your having done that. The vast majority of warranty claims would not be effected, and I've never seen any reports of that happening. But there is some minimal warranty risk involved, depending on the nature of the claim.
My own personal experience is that I had the CAT on my 2013 RT removed in 2014 due to excessive engine compartment heat - especially under the fuel tank. BRP is aware of that and has never denied any warranty claim. I have a 4-year warranty. As a courtesy, BRP did remind me of their right to deny a related claim when I recently applied to extend my B.E.S.T warranty for an additional year. (You can buy up to 5 years of coverage.)
Ozzie Ozzie Ozzie
Curious. ....
How do you listen to your music....through speakers or headset...?? I use my G9+mp3 and have a Yoshimura R77 pipe no problem. Although not to true to the sound, you tube has many systems on there you can reference....
If you are just after a little 'better' noise, I'd lose the Cat & keep the stock muffler - same look, deeper & throatier growl from the pipes.
That is the response I got when I removed the CAT and kept my secondary muffler intact on my 2013 RT with the 998 engine. An exhaust note that has a little "deeper & throatier growl" is exactly the way I would describe it. It's a little louder but not obnoxiously so. Plus, I got a bit more low-end torque. IOW, it is a bit more responsive off the line. It feels like I may have gained some mid-range torque as well, but I really have no effective way to gage that.
I realize that none of this is really answering your specific question. If anyone on the forum has actually installed the GPR muffler on a Spyder with the 1330 engine, hopefully they will chime in here.
Speakers or headset!
First ,Thanks for your reply. I don't have helmet or headset. I use the speakers and find that I can hear up to 75mph give or take a little. Have been listening to same music since the sixties so if it is drowned out a bit , no problem just pick it up after. Niterider
