SpyderLovers Sponsor
MotorcycleDave Gel
My MotorcycleDaves Conformax seat Gel will
never go flat even if you stab it with a knife😀😀😀
Originally Posted by Cruzr Joe
No ...................... Not my tire
MY AIRHAWK "R"
the repair kit that they provide with it works great, no more flat.
no comments regarding weight limits will be tolerated.
Cruzr Joe
Me and my Airhawk "R" have been thru a lot, i wont abandon it.
Cruzr Joe
MY AIRHAWK "R"
Cruzr Joe
So here is a question about flats. I had a leak in my car and used fix a flat. According to the sears mechanic, they said it messes with the sensor in the valve stem. We replaced the tire. Question is: what do you carry for a flat? Does anyone know if fix a flat would be contraindicated with all of the computer sensors the Canam has? Thank you
Sent from my SM-G900V using Tapatalk
If you've gotten a flat tire while travelling; do what you have to do, to get the tire to hold some air...
The computer is only reading tire rotations via the ABS sensors (so it figures out the tire diameters...). As long as all three tires are spinning at about the same rate: you're good to go!
The best I have found is RideOn. I have ran it for many years in all my bikes. I have found nails and screws in my tires and never had a flat.
Tire plugging kit and a compressor.
looks to me joe were giving all are lovin to you.
Tall flag mount, spyderpops skid plate & stainless steel screen mesh, airhawk adjustable cushion, raised white lettered tires.
and I also carry some of that fix a flat stuff too just in case because as Bob D said, do what you have to do.
Gary
When i go on trips i have a conti seal kit & tire plug kit with me, so far i haven't used either.
What repair Kit??
MY AIRHAWK "R"
Cruzr Joe
I just bought an Airhawk R and there's no repair kit in my box. Did I get cheated?
