stripped oil plug
I have seen that other people have replaced the oil plugs on their bikes. I did the first oil change on mine today but, I had an oil plug strip on me. I had the correct "T" tool and it still stripped out. I did get it out and drained the oil. I do not want to put that one, or the other one back in there. I have looked and found another oil plug that others have used but $63.00. I will look and ask if anyone knows of any that do not cost that much.
Look at goldplug.com
Theirs are about $40.00 for the pair.
SpyderLovers Sponsor
Done
Buy the Dimple or Gold plug, and be done with it. I'm not finding a quality alternative, and I do lots of oil changes. Go first class, Marine!
Joe Meyer
Dimple or Gold plugs
I switched over on the first oil change. Honestly cant remember which one. When I did the next oil change ( dealer did the first, checked off and signed the owners manual) it was soooooo easy. No guessing weather it's a hesx or a torx, no stripped out bolt, easy torque setup.
Stripped oil plugs cause::::::::
Kaos
I would get a gold plug.
I had a dimple plug snap in 2 leaving half the plug in the clutch cover. It was a $1100 job to get replaced.
There is also another forum member who had the same plug snap in the same spot.
I did compare both dimple and gold plugs and the gold plug seems like a better quality product.
Just a note that the dealer installed the dimple plug during first oil change.
They claimed they did not over torqued the plug.
Also the member who had the same problem happen also claimed he didn't over torqued the plug.
Yes the "T" does mean torx tool. I have a 2015 F3-S and yes the head of the drain plug is stripped out. I looked at the dimple brand and found them to be $63.00. That is way to much. IMHO
The Gold Plugs MP-01 and MP-18 are a total of $40 without shipping. Go to goldplug.com
Striped my T plug as well on 1st oil change. Spend the money and buy the Dimple set.
It baffles me, why folks will spend $20,000 or so on a motorcycle, and then balk at the cost of an aftermarket accessory for it...
STRIPPED PLUGS
OK now I know what your issue is, and the answer is the GOLD PLUGS , they have strong magnets and work just as well as the Dimple brand.................I only re-placed the large PLUG ( the Torx ) the small one ( HEX insert ) was never an issue when using a Ratchet .................Mike
I just ordered a set of plugs, gold plugs, on EBay. They cost $43.00. That is better than the $63.00.
the oil plugs that were $63.00 were the dimple plugs. I went to their website.
Hey, fellow Marine! Diego or Parris??? I did mine at PI in '74. Don't mind Mike, he is working on his social skills......right, Mike???
Gold plugs?
Which ones do u need for the F3S. Gold plug has 3 listed for the F3S; MP-01, MP-02 & MP-18
2015 F3S SE6
You don't stop riding because you get old, you get old because you stop riding
SOCIAL SKILLS MY A**
I did the PI in '83. Semper Fi
I got out of the Corps in '93 and worked in a Federal Penn for 22 years. I had to deal with all the crap you put in jail!!
yep dimple snapped in half
that was me, my dimple plug broke in half right at the magnet the very first time I put it in and it WAS NOT over torqued.
I think some may be defective. VERY EXPENSIVE OIL CHANGE.
Leon
2022 marsala red RTL
AND
2014 RT S SE-6 COGNAC, 2010 RT 622 TRAILER TIMELESS BLACK
BRP trailer hitch, Utopia back rest, Baja Ron sway bar , heim links. Elka stage 2 shocks front and rear.
TricLed fender lights, saddlebag lights and mirror lights. LED headlights and fog lights, Wide vu mirrors.
spyderpops LED bumpskid ,zippered cargo bag linings, Laser Alignment by Netzleys Tire, Stebal air horn
stant gas cap,( Dimple oil plugs REMOVED ) JT dash mount.
(Onboard) Lamonster Garage air compressor and intelliboost charger.
On your F3, one plug is torx, the other is hex. What sort of tool were you using? You need a torx drive socket and ratchet, not a key. If the head striped out, the wrong tool was used or not fully inserted.
I do not recommend the dimple plugs. They are worse than the OEM in terms of failure. Having done MANY spyder oil changes, the OEM plugs are just fine if you use the right tools to remove and install them. Dimple refused to stand behind their defective product. Once you see a snapped off Dimple plug, its easy to see why they fail from the very thin wall under the o-ring. Bad product.
DIMPLE VS. GOLD PLUG
...........JC, I have the GOLD brand and I've seen pics of the Magnet in the Dimple brand ...... It looks like the Dimple has a larger magnet and I think this is the problem .......the larger magnet causes them to drill a larger hole in the plug , thus making the walls thinner, thus the failure...................jmho.......Mike
