Results 1 to 13 of 13
    Jul 2013
    peru, illinois
    Default RSS 2012 SE5 Front Tire Sizes????
    Stock front tire is 165 65R 14. Will a larger size fit in my fenders- 175 65R 14 which gives more choices!! RSS owners-what car tires are working for you? Thank you. John
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by spyderwing View Post
    You might have to put washers on the fenders to help for room. I have a set of the same size in my shop waiting till my front wear out.
    David
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Default No need for washers...
    Quote Originally Posted by Warlock View Post
    David
    We use 175/55R15 with no problems on our 2013 and on. So, it will also fit on your 14", it is the same fenders....
    Richard
    Richard
    * 2012 RS SE5 (hers)
    * 2013 ST SM5 (mine)
    Daughter RSS SE5 2014
    Son in law RSS SM5 2013
    P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
    2 sets of Kumho 175/55R15 front tires
    1 set of Hankook V4
    1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
    Jul 2013
    peru, illinois
    Default Tires
    Thanks. What tires are you using?
    Oct 2009
    ponte vedra beach fl
    I went with the larger tires on my 09 close but dosent rub
    Quote Originally Posted by hecoon View Post
    What size???
    Feb 2016
    Where ever we can ride
    I put 175/65 R 14 Kumho Solus on the front without any interference issues. I like them. Reasonable grip, will slightly understeer if you push them hard enough, but at that point you'll have high lateral G forces.
    Oct 2009
    Quote Originally Posted by Koop View Post
    that's is the tire I have on my 09 rs
    Jul 2013
    peru, illinois
    Default RSS Front Tires
    2012 RSS SE5. Just installed General Altimax RE 43 on the fronts. Went up one size to 175 65 R 14. They fit fine. Had a General on the back so matched them up. They feel good- rode today on wet roads and felt like a great grip. 16 lbs. in the front and 26 rear. Thanks for the help.
    Default THE ALTIMAX
    I think you meant ....RT 43 ..... I have been recommending this tire for quite awhile now I think you will really like it long term.......This is just a suggestion try lowering the rear to 22 PSI ... the sidewalls are plenty stiff enough to support even two up riding ......... Mike
    Jul 2013
    peru, illinois
    Default Altimax
    Knightrider- You are right RT-not RE. Will try the lower tire pressure as it has been a stiffer ride with 26 Lbs. Thanks. John
    Jul 2013
    peru, illinois
    Default Altimax
    Sorry Blueknight 911. Too much coffee. John
    Default LOW psi
    . Accidently I ran my Michelin at 6 PSI very slowly to the nearest service station.....and the RIM was not touching the ground ( I had no choice )...... I'm sure the Altimax could do the same ..........just sayin....... Mike
