Results 1 to 20 of 20
    Default When did your Spyder "loosen-up"?
    For it's first 10,000 miles or so; my Spyder averaged 39.3 mpg.
    After the trip to Missouri at the end of April, I noticed that it was getting noticeably better fuel mileage.
    Since I hit 13,000 miles: it's been averaging 41.6 mpg.
    When did you guys notice that things had loosened-up, and your bike was ready to start running the way that you knew it could?
    Default LOOSE SPYDER
    After about 8,001 miles ................ but I drive it harder ....... Mike
    8,000 miles? That's about when my 2010 RT started loosening up...
    Thanks!
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default Just turned 10,000 on the 1330 - got three tankfuls at 41 plus MPG
    I was thinking that it finally was "broke in". Either that or it always 'seems' to run better after a fresh oil change
    2015 RT , OEM Black Gloss
    Nov 2012
    Pueblo Colorado
    Default Maybe you blew the 'carbon' out on your trip to Spyderfest?
    Every now and then you need to open her up a little?
    It might have happened on that trip!
    ...A little bit!
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    at 2500 miles and new oil it seems to shift up and down quieter. never been
    less than 38 mpg since i got it and mostly 2 up. never rode w/o a helmet till
    last night. noisier than anything else ive ever had.
    [joyce & irvin toms]
    Jul 2016
    SE MA
    Default MPG Figuration Method
    What method are you using to figure mileage? I've got a 2015 Rt with a little over 1,500 mi, and I'm getting 30-31 mpg. The display reads something higher but I don't get anywhere near that number when I top off the tank and divide miles by gallons. Perhaps this is because; its still breaking in, my computing method is faulty, or its my driving style...
    Steve
    I don't remember exact mileage for the engine getting more loose. The 998 gets 31 or so and the 1330 gets 39 or so. Both now have 23,000 miles plus on the odometer.
    This summer, we have not gone on any longer trips. I can do between 70 and 100 miles and I have to get off. Hopefully, that will be fixed by next riding season.
    Default Don't know. ..!!
    I never paid attention to mpg's till I came here and saw how worried everyone was... performance wise..as I made mods to the electical and air systems. The handling for the same reason. I always ryde my vehicles the way I will ryde them from day one. Then having had many vehicles getting only 8 to 10 miles to the gallon 31 avg is just awesome.. sooo gotta bow out of this one with "I don't really know"...
    May 2016
    mt morris il
    Quote Originally Posted by Uruzgan View Post
    Steve
    old math. they used to call it division back in the 50's and 60's.--irv
    Dec 2014
    Lee's Summit, MO
    When the the gas gauge goes down, I stop for gas. From the looks of things, I need to do a better job planning my trips so that they are all downhill and the wind to my back.
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    Not sure how to measure... I think I get less on my f3s
    Live, Love, and Ride! God Bless!
    Coolidge Arizona
    Quote Originally Posted by kngfsh27 View Post
    If you keep going down
    sooner or later you will reach the south pole
    then you have nowhere to go but up
    Nov 2012
    Pueblo Colorado
    Default And then you hit a headwind and get run when you only get 32 MPG..
    I know its hard to get an accurate MPG on one tank, and this weekend we had a run of 160 miles mostly into the wind at 70 mph..... result - took 5 gals after the 160 mile run.. Speed and air resistance does take its toll on energy required...but Premium gas was cheap in Oklahoma
    Apr 2015
    Green Bay, WI
    My F3's--did my 1st oil change at 2200 mi, I will say the F3's has ran better with more miles on it, Initially it shifted slow--long delay--30 mpg. Now it shifts much quicker and I'm guessing mpg is 33-34 mpg. I haven't been on a long trip but I believe 40 mpg would be possible if I stayed below 75 mph on the freeway. 1st 500-1000 miles were the worst. 1330 likes to run loose.
    Darrell
    Active Member lonestar2112's Avatar
    Sep 2018
    Spanish Springs, NV
    Seat of the pants, I get upper 30's. 2K miles. Mostly 2 up and we ride like it is stolen!
    Need to do more traveling
    RE: Gas Mileage
    zero one of the trip meters each time you refill the gas tank. Use that number and divide by the number of gallons the pump says. I also fill to the same level each time...that keeps things a little more accurate...but it is still not perfect.
    I also do not worry about decimal places beyond the first. 4.8689 gallons will be 4.9. MPG numbers (38.64338--will be 38.6).
    Those five decimal places give the impression of more accuracy than is really there.
    Nov 2018
    Claremore, Ok.
    I've got 13,400 miles on my 2015 RTS and it's getting around 35 mpg. I've wanted to ask ya'll what rpm is where you try to keep it at? I try to keep it at 3000 rpm and rarely goose it above 4000 rpm (hard to hold onto her above that, it really wants to roll me off the back end). It really pulls hard from 3000 rpm. However, I do often find it above 4000 rpm when I've forgotten to shift up (damn that C.R.S.!).
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Northern Kalifornia
    Revalden, I got 40 mpg day one on my first tank. I've also gotten a couple of 32 mpg tanks since then. Those were mostly 70 mph on the freeway running against a head wind. Many conditions effect mpg but I bounce around in the high 30's and low low 40's. I shift between 2.5k and 3k rpm most of the time and hover around 3k when in 6th gear. Pressing the corners in twisties and running high rpm's will suck gas like it's going out of style. My days of riding hot are behind me now so my equipment and gas last longer these days. However, when my warrantee is up, I'm going to get a ecu flash 2. Why? Just because I can! I've shifted at 7k a few times and it's fun bit it is also scary.
    Last edited by Peter Aawen; 10-23-2019 at 02:42 PM. Reason: Removed 'collateral damage' quote. ;)
