Results 1 to 7 of 7
Thread: Hitch Removal
    Feb 2014
    Brown City Michigan
    Question Hitch Removal
    So I bought a 36mm socket today so I can align my belt to keep it from rubbing the flange.
    Is it easy to remove the BRP hitch to access the axle nut?
    Thanks,
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by Bogie View Post
    Thanks,
    Very easy, takes about 15 minutes. That's with a break.
    You just need a 3/4' wrench and a 3/4" socket to remove the shaft that goes through the rear axle. A pair of needle nose pliers to remove the cotter pin holding the nut in place (to remove the shaft).
    2020 RT Limited , Chalk
    washington state
    Do you lose the adjustment of the belt?
    Default BELT TENSION
    Quote Originally Posted by jerpinoy View Post
    NO because the bolt for the hitch is completely separate from the axel pressure/tension .....You are not loosening the AXEL................Mike
    Jul 2010
    Las Vegas, NV
    Default Easy
    Remove cotter pin. Remove castilated nut. Remove hitch axle ( bolt). Take a rubber mallet, beat the hitch ball to the rear. Hitch comes off with a few blows.
    Joe Meyer
    Feb 2014
    Brown City Michigan
    Thanks everyone, this group is awesome!
    Mar 2013
    Maumelle, AR
    I forgot to mention, when you're sliding off the hitch, be sure to move the brake line (on right side) out of the way. You only have to move it out an inch to clear so the hitch can slide off.
