RT rear speaker sound
2016 RTS. Is there a way to get the rear speakers to work with iPod in trunk?
There should be a setting to turn them on under "mode" on the dash. Check the fader settings in audio.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
![Quote](images/misc/quote_icon.png) Originally Posted by BLUEKNIGHT911
First you must set the system to Aux. function to use an I-pod or MP-3 etc..... Then go to Audio settings and make your adjustments to suit ........Mike ![thumbup](images/smilies/thumbup.gif)
Not correct.
You set it to AUX for a MP3 player. That is any player that you connect via the 3.5mm audio plug.
If you have a supported iPod you use the iPod cable. Set it to iPod which will show up ONLY if you have a supported iPod connected.
Bob
I-POD
No sound in rear
![Quote](images/misc/quote_icon.png) Originally Posted by finless
Not correct.
Bob
That is the way I have it. I'm using the iPod cable. Get songs on dash. Can skip songs, etc. just don't get sound out of rear speakers. Balance set to middle. Just wonde5ing if there is way to get iPod sound out of rears.
The input from the rear port is just that: input. There's nothing about it, that prevents it from being distributed through the system in the manner specified.
Are you "473% surely positive", that you're getting sound from the rear speakers, when the radio is playing? ![don't know](images/smilies/shrug.gif)
(Sorry: it had to be asked.)
I wonder if one of his speaker wires is not connected and thus causing no sound. Easy enough to pop off the rear speaker and check those connections if the "Fade" is not working.
![Quote](images/misc/quote_icon.png) Originally Posted by Chrisluckey
Balance is middle but what about fader?
2016 F3 Limited
2019 Ryker Rally
2020 CSC TT 250
Resolved
![Quote](images/misc/quote_icon.png) Originally Posted by Highwayman2013
OK issue resolved. By having the FADER set to CENTER, the fronts were over powering the rears. Had to move balance more towards the rear to hear both equally. Thanks to all for the input.
