RT GAUGES GONE
Well, I finally got tired of the wildly inaccurate analog gas gauge, and figured that if I was going to disable it I would do the same with the temp gauge. To my surprise and annoyance, the gas gauge "remembered" what the fuel level was, and the needle stayed in that same position as before it was disabled. I kept looking at it and thinking, "I'm gonna have to get gas soon". Then I would remember that it was disabled, look at my mileage, and the bar graph on the center screen for the actual fuel level. So I decided to take them out. I went to a local boat dealer and had them order two 2" Euro Blanks (that's what the manufacturer calls them) made by Faria Marine Instruments. Took out the gauges, and put in the blanks with a small bead of black silicone around the bezel to keep water out. So here is the finished product at a cost of $35.00 and 20 minutes of labor. I like the way it looks. Now I have to retrain myself to look at the center screen, not at the - nonexistent - gauges.
![](signaturepics/sigpic14272_8.gif)
Nicely done...
Did you consider adding other guages..voltmeter etc or charging ports..?? but for a clean look ...you nailed it...
Analog guages
I have a 2015 RT base model. No analog guages. I could never figure out why BRP installs redundant analog guages when the digital guages are just inches away. But that's just me.
It was probably done to differentiate between the Base model, and the upgraded ones! ![thumbup](images/smilies/thumbup.gif)
Back in 2010: my A&C model had the gauges, but with Black trim around them. The RT-S had the chrome bezels.
Good job Dwight. Looks nice and clean.
took mine out a long time ago, replaces the with a volt meter on the right, and a 12 volt outlet on the left
Faria Link
I didn't really want any other gauges, which is why I went the blank cover route. Here is a link to the Faria site which gives a list of distributors. The part number number is 12861 Euro Blank in black, 2" diameter, not to be confused with the 4" diameter blank. No picture, but it is on the bottom of page 13 of their online catalog.
http://faria-instruments.com/distributors.php
http://faria-instruments.com/site_ma...log-150825.pdf
For a clean look you nailed it!
I replaced mine with a 12v on one side and a dual USB on the other side.
JT
help me out
![Quote](images/misc/quote_icon.png) Originally Posted by oldguyinCT
Ok, so help me out on the "wildly inaccurate" comment. Was it overestimating how much gas you had or underestimating?
And is it possible to show the digital gas gauge without disconnecting the analog?
No the digital gauges only come up when BOTH analog gauges are disconnected.
![](signaturepics/sigpic9193_3.gif)
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
![](https://www.spyderlovers.com/forums/maps/map.png?states=AZ.CA.CO.ID.MT.NV.NM.OR.SD.UT.WA.WY)
Please excuse the dumb question: Where did you guys get the USB, voltmeter, or 12V outlet that fits in the analog holes? Do they come with the correct plates or did you improvise?
Thanks for the help.
Dave
When I disconnected mine, I filled it up first so at least the dead analog gas gauge is stuck on full. I put a Voltmeter in place of the temp gauge on the right. One of these days I'll yank that dead fuel gauge and replace it with something, like a clock that actually keeps time.
Pam
![Quote](images/misc/quote_icon.png) Originally Posted by KosherKid
Dave
I got my voltmenter on Amazon. 52 mm is the perfect size.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Pam
![Quote](images/misc/quote_icon.png) Originally Posted by Pampurrs
Pam,
Where did you mount it--replace an existing gauge or add another bracket?
Darrell
![Quote](images/misc/quote_icon.png) Originally Posted by Wildrice
Pam,
Darrell
I took out the temp gauge, tapped into the existing positive and negative wires for the voltmeter and slid it into place. 52mm fits perfectly.
Pam
![Quote](images/misc/quote_icon.png) Originally Posted by rookieryder
Prior to 2014 the RT analog gauges were worthless, they tended to bounce and they didn't give you a good idea of how much fuel you really had. The gas gauge on the 14 and newer are pretty darn accurate.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
The gas gauge always showed less than I really had in the tank. And, as Pegasus1300 said, you have to disconnect both analog gauges to get the fuel and temperature bar graphs to show up on the center screen.
![Quote](images/misc/quote_icon.png) Originally Posted by DJFaninTN
Good looking out to find this site. Others that I looked at had similar pricing, but they also had a minimum purchase, which 2 blanks did not equal. So, I ended up paying twice the price, but I got and installed them right away, so I am OK with paying more. Plus, I'm supporting a local business, which I like doing whenever possible.
Ozzie Ozzie Ozzie
![Quote](images/misc/quote_icon.png) Originally Posted by Bob Denman
"Prior to 2014 the RT analog gauges were worthless, they tended to bounce and they didn't give you a good idea of how much fuel you really had. The gas gauge on the 14 and newer are pretty darn accurate. "......
There's no denying that after 2013, the fuel gauge accuracy got a helluva lot better, at least as far as the bouncing around & wildly innacurate readings were concerned; but sadly, even tho the 2013 & earlier digital 'bar graph' is more stable & better reflects the progressive fuel use, I've found that the sender itself is really, REALLY inaccurate too, and even tho the digital gauge now shows a progressive reduction from full to empty as I ryde, it NEVER shows a true 'Full', and when it hits the bottom bar and the fuel light comes on, I invariably still have AT LEAST 1/2 a tank of fuel left....but it's still never the same 'progressive fall' from full to empty either!! ![shocked](images/smilies/shocked.gif)
Sometimes, it says it's only 3/4 full when the tank won't hold another drop, then it dives to empty and shows the low fuel warning light after just 35km of ryding; other times it sits on full until I've ridden 200km then suddenly drops to empty/low fuel light in the next 10km; or the bloody thing starts out OK & even looks like it might do the right thing as it slowly & fairly accurately follows my fuel usage over the first 1 or close to 200 km before dropping to empty/low fuel warning light status soon after & a dip of the tank shows it's still close on or above 1/2 full!! ![Mad](images/smilies/mad.png)
So these days, rather than using the appallingly inaccurate analogue gauge, or the slightly more accurate digital gauge, I just work off my trip meters!! Since I had the Rotax Racing ECU Upgrade done to my V-twin, it's been great - Cruising solo or 2-up, a full tank is generally going to be good for something over 400km; fanging it around the Hills or playing boy racer with the Highway traffic it's good for about 300kms; and that's a whole boat-load better than it was before & quite respectable for such a wind-jammer of a bike! Besides, the trip meters are consistantly accurate and have never varied in their 'rate of registering the kms' - altho I must admit that sometimes the 'reported distance travelled' doesn't really reflect my actual 'distance made good' over the ground, despite accurately reflecting how many times the rear tire has turned & how far it has 'theoretically' travelled - but usually if that's the case, then the speedo may also have said I was travelling at about 90 kph for a bit while the byke was barely travelling at a walking pace!! Oops, my bad!! But it is fun!!!
My replacement
My replacement
