Results 1 to 25 of 46
Thread: air scoops kit
    Very Active Member btcherm's Avatar
    Howard City, Michigan
    Question air scoops kit
    just got the air scoop kit no introduction who know how they should bolt to gather and where to cut panel
    need some help .....
    Active Member Doc - Riverside's Avatar
    Jan 2010
    USA Folkston,Ga
    Quote Originally Posted by btcherm View Post
    PM me your E-mail address and I'll send you my procedure on how to install them.
    Jul 2013
    Vestaburg Michigan
    I sent you a PM.
    Very Active Member zuni's Avatar
    Mar 2014
    JAX FL
    Quote Originally Posted by Doc - Riverside View Post
    Just did mine with the help of Doc's guide. If you are afraid of the marking part call your dealer. They probably received the install kit from BRP withe the marking templates. My dealer offered to mark them if I brought them in. I was going to but in the end followed Doc's detailed instructions (with a few liberties) and all went well.
    CJ JAX
    Feb 2014
    Wellsboro, PA
    Default scoop shapes
    With all the talented people on this site i would of thought someone could design scoops with some style. Something functional yet classy. Like the scoop on a 1971 barracuda. I may have kept the 13 if BRP would of thought about appearance as well as function.
    Doc thank you for your help and picture it help a lot .........some day I can help you.......
    Quote Originally Posted by Larry rt View Post
    I sent you a PM.
    Thank you Larry ,doc sent me some good picture ,so I will get it done monday, I have a vet ride with the A.L.Ride wont be back tell
    6pm.
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by WellsboroSpyder View Post
    I like mine.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    I think this is the first negative comment about their looks I have seen. I thought they blended in quite well with the lines of the Spyder, but to each his own. I think yellow Spyders are ugly, but then that's just me!
    Feb 2014
    Wellsboro, PA
    Default agree
    I agree everyone has their own taste, but this is not the first negative. There were a few of us dissapointed with the looks and or color matching. I'm glad the scoops are out there for people to choose to put on if they like the looks.
    May 2009
    Connecticut
    Like the Looks OR Not- They lower my Temp from 5 Bars to 4 on a 90 Degree day and I am running 2 Bars in the late fall and winter- I think the engine may freeze up????
    I said 3-4 Years ago that those acoustic Panels were CAUSING the heat problems because they COVERED the cylinder heads and Created the heat in the gas tank and crouch Area?
    Finally someone listened ???? Now you hear More engine noise BUT your running Much cooler !
    Sea Doo GTI-SE 90 Jet Ski!!
    Apr 2010
    Montreal,QC
    that.
    I don't cut anything i use the already hole and i remove only the grill , with the scoop the air is force to go inside... when i install it i would not want to mess with cutting anything i try it like that it reduce 5 to 4 bar so i decide to leave it like that.
    Acworth, GA
    Default Painted
    I just completed painting the Scoops on my 2012 looks a lot better with out that black mass on the side on the bike.IMG_1962.jpgbefore / afterIMG_2163.jpg all the info in a thread here see (painted air vents)
    indpls in
    Default heat
    i ask my dealer about those scoops for wifes 2015 she complain about heat he said he checked with brp told they not fit her rt
    Acworth, GA
    Quote Originally Posted by fatboy View Post
    Hi fatboy i was just looking at some 2015 rt's and it sure looks like they would fit to me the 2015 has the same air deflector and small vent that my 2012 had before i installed the air scoops. maybe you could start a thread and see how many have installed them on their 2015's
    Here's a pic of the slickest installation that I've seen so far:
    I think that they look pretty darn nice!!
    Mar 2014
    JAX FL
    Quote Originally Posted by Lava Flow View Post
    One of the guys that rides with us has a 2015 and put them on his. I followed his lead and put them on my 2014. Didn't really have heat issues other that the glovebox and the scoops have taken care of that.
    CJ JAX
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    Default Great minds think alike
    Had mine done & painted by dealer last year.image[1].jpg I didn't like all the black either.
    Ride safe!
    2022 Sea-T0-Sky
    Default air scoop
    I like the look of my just being black it go good with big blue...IMG_5142.jpgIMG_5141.jpgIMG_5140.jpg
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    I have them on my 15 RT and they fit fine, look pretty nice, and certainly work. (keep the center section of the Spyder much cooler on the HOT Florida days.)
    David
    May 2015
    United States
    What would the part number be? Thanks
    Oct 2015
    N.E. Florida
    Do a ssearch for "Doc Riverside" and you will find all the information you need to get the kit, and do the installation.
    David
    Active Member scarecrow's Avatar
    largo, florida
    Got my scoop kit in this week. Hopeing to pdf.file from Doc. Soon.
    2014 RTS , Cognac
    Nope, not just you - me too!! Certainly not Slingshot ugly, buuut......
    Sep 2016
    US. ohio n/e
    Quote Originally Posted by zuni View Post
    CJ JAX
    How much do they cost
    Sent from my LGLS675 using Tapatalk
