Results 1 to 15 of 15
    Dec 2012
    Murphy, NC
    Default HELP!! WON'T SHIFT INTO FIRST!!
    Cranked up the F3-S this evening and backed out of the garage normally. Went to put it into first and it wouldn't shift. Gauge kept going from N to E and back to N again. Reverse works normally. If I try to shift into first with parking brake on, no change in RPM's. If I try to shift with parking brake off, rpm's rev up to 1300 and then quickly back down to 900. Hope it's not a transmission problem. No active codes and I'm calling the dealer tomorrow. Perhaps gear position sensor? Only have 5100 miles on the Spyder. This is my only hiccup.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Default Little checking..
    On the older model V-twin you could go to the linkage and manually shift. Check your manual and see if it mentions this. It may be hung up or loose but you should be able to put a wrench to it and shift it out of reverse and then try to see if the other gears work....
    Invalid Emails
    Sep 2015
    Cheshire Ma
    SE or SM does it go into neutral or stuck in rev ?
    Dec 2012
    Murphy, NC
    ​It's an SE6. Will shift into reverse and back to neutral. Just won't shift into first. My manual says if it won't shift have it transported to a dealer. Hope it's just the gear position sensor.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Aug 2008
    Maryland
    Quote Originally Posted by JKMSPYDER View Post
    Most likely Gearbox Position Sensor (GBPS) - dealer will even know if your VIN# is one of the ones with service bulletin to clean out gearbox of contaminates and replace sensor. Keep us posted
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
    Sounds like gear position sensor issues. Let us know what the dealer says.
    Aug 2015
    Myrtle Beach S.C.
    Default How many miles
    Can I ask how many miles you had on your F3 when you did the first oil change?
    Nov 2015
    Myerstown, Pennsylvania
    Default Safe...
    Is it safe to assume it shifts to neutral when starting it?
    Active Member BamaJohn's Avatar
    Feb 2015
    Talladega County, Alabama
    Default forgive me, but....
    .......make sure your foot's on the brake...or it won't shift into 1st.
    jb
    John B.
    Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
    Nov 2015
    Default Brake switch....
    Quote Originally Posted by xwingnut View Post
    jb
    I'm not sure but I thought I saw something on here about brake switch issues possibly linked to this problem. Anyone else remember seeing a post??
    Dec 2012
    Murphy, NC
    Trailered it to my dealer today. They can't get to it until next week. I told them that was cool as long as I have it back by July 8. I'm leaving for Deadwod on the 9th. Will go into reverse and N just fine but not into 1st. (And yes my foot is on the brake). I'm hoping it's just a gear position sensor. They checked my VIN and nothing popped up about bad GPS from the factory, so we will see. When I try to go into 1st I get N and then E on the screen. Could not pull up any codes. Will let everyone know what I find out. Oil was changed by the dealer at 3000 miles. I now have 5100 on it.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Aug 2008
    Maryland
    If it turns out to be the gearbox position sensor - it will be ironic for me since my 2008 Spyder that I traded in for F3 had its GBPS replaced three times. Fortunately my 2008 was an SM5 and would shift correctly just the dash went bonkers with E on screen.
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    IF the dealer knows that the VIN is one of those on the SB, then SHAME on the dealer for not replacing the sensor PRIOR the sale.
    AJ
    Quote Originally Posted by BeRight View Post
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Mar 2011
    gaines Michigan
    I had a gear position sensor replaced on my 2015 rt first seventy miles.
    Jul 2011
    Mount Airy,Ga.
    I will for you and hope you get to Deadwood. If they can't fix it you may want to try Gainesville Motorsports
    and ask for Tom Howell, he has worked on Spyders since 2008. Sharon called BRP started a Case Number, BRP became very helpful and had there techs call Tom. I hope to get my Spyder back in the next few weeks, due to parts. So good luck, and let me know how what was wrong when you get it back.
    Mike and Sharon Fleischer
