RS clutch slave cylinder failure
Symptoms and cause follow:
2013 RS w. 5300 miles, observed lack of resistance when depressing clutch lever. Hyd fluid was low, filled to full mark in reservoir. 6 weeks later, same situation happened again - had to push clutch lever all the way to the handlebar to make a hard shift. Brought to dealer.
Dealer's shop determined it is a failed clutch slave cylinder. The mechanic said the o-ring seals sometimes fail, easiest to replace cylinder unit (instead of o-ring). This is about an $80 part and 2-3 hours (fortunately warranty is still in effect on my machine).
Hope this helps if you have the same issue.
-Bodgerist
rs clutch slave cylinder failure
I don't think there is a rebuild kit available, as unlike HDM, there aren't 100K of these units floating out there on the streets awaiting failure. I could however be wrong as I often am
2018 F3-T
Your right....
Originally Posted by hillrad
No warranty here. Replaced leaking slave O rings last year. Including six pack... <$10.
Information please size and where found
2018 F3-T
I change the fluid in the clutch system of my '08 GS SM5 after each riding season. So far so good. (15,000 miles altogether)
2008 GS SM5, Full Moon Silver
2007 Piaggio MP3 - 250cc
Nicked o-ring
I got my machine back - the culprit was a nicked oring on the slave cylinder.
RS clutch slave failure
Hilrad, Thanks for the information, have it bookmarked
2018 F3-T
Clutch exploded view - thanks!
Excellent ref - thanks for the link!
I believe it was item 10 they replaced.
-Bodgerist
-Bodgerist
Hopefully they replaced all the o rings while it was apart.
2008 GS.....PE # 2888
replaced o-rings
I think they replaced several - and the helper spring.
Tags for this Thread
