Little checking..
This was an issue on the older models and they came out with an improved version. If you are doing your own work it is well worth getting a shop manual online it will make things so much easier.
radiator canister cracked
One other thing to consider is you now need to completely drain your coolant and replace it all. Bad things happen when you mix antifreeze colors.
And yes there was a service bulletin on changing these canisters; check with your local dealer.
2018 F3-T
Don't forget to take hose off on lower radiator to drain many have ruined the radiator trying to remove the drain plug which cracks the glue job
2 happy happy spyders
What is the correct color to get? Even BRP sells two types. My 08 GS has the green in it.
I had to replace my tank last summer, on my '08 GS. The dealer did check with BRP, but it wasn't covered. Cost was around $60 - $65. I agree with the above poster, who stated to remove the lower hose from the radiator to drain. Do not remove the drain plug. It's really not that hard of a job to change out. Good luck.
2008 GS.....PE # 2888
Our bikes do not have DexCool in them. As long as you use an antifreeze that is safe for aluminum engines it doesn't matter what color it is.
While I was tracking down the hose leak last year I topped off with green (safe for aluminum.) When I drained and flushed last year (removed the drain plug btw with no ill effects) there were no clumps, no sludge, just slightly less orange antifreeze. Flushed with distilled water, still no problems. Filled it with green and it's been fine ever since.
Don't overthink this.
Trb-- (Roger)
2022 White Pearl F3T
Spyder States Visited
Was changing my coolant with the BRP green fluid and needed to get more for a good flush. Found out it's not made anymore and only orange was available at the shop. Ouch!
According to the shop a bulliten says you can't mix it, but the Tech line say's you can. Huh. Flushed once with orange and refiled with orange. The problem with this is that only a third of the fluid drains out (2.2 qts of 3.2 qts). Means a little green is left.
Any insight on the issue?
If you mix the two different color antifreeze's from BRP it will coagulate and screw up your radiator system, BRP specifically states DO NOT MIX DIFFERENT COLOR ANTIFREEZE'S.
Cruzr Joe
Cruzr Joe
Where? I've read my owners manual (and the relevant portions of the shop manual) multiple times and can not find anywhere where BRP says to not mix different color antifreezes.
And as I said in my original reply, when I changed and flushed my antifreeze, there was no coagulation.
Trb-- (Roger)
The tape you used is a self-fusing wrap - it only sticks to itself and will not adhere to the surface. It's for wrapping a cracked hose or pipe or insulation on a wire or cable.
I've found my Spyder pretty easy to work on once I got over my initial worry about the differences from a 'normal' motorbike. The RS's are straightforward really and it is satisfying to work it out for yourself. Problem is now you've started tinkering you'll find all sorts of changes you want to make as well as the normal maintenance:-)
