2016 rt tire gauge
Hi Folks: What type, make of tire press gauge works for this rt.
NB asking stupid question.
Tire gauge reply
THANKS for the help!!! Greatly apprec. it
I use Joes racing gauge purchased off amazon.com
Here is a sample of the type I find easy to use on the rear tire. Get one with a 90o chuck. You don't need one that measures more than 60 PSI.
http://www.amazon.com/TireTek-Flexi-...le+tire+gauges
You may also want to check out the FOBO tire pressure monitoring system. With the tpms you never have to guess what your tire pressure is and you never have to get down on the ground unless you need to add air. Then the bonus is you can put air in and screw the FOBO back on to see what your pressure is. No need for any fancy gauge.
You can buy them from Lamonsters Garage and they are also available on Ebay
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
