uh oh stripped drain plug
I was changing my oil and went to loosen the drain plug on the right side and it just spins
I don`t even want think what that's going to cost to fix . so much for saving money ![yikes](images/smilies/22yikes.gif)
Leon
2022 marsala red RTL
AND
2014 RT S SE-6 COGNAC, ![Spyder2](images/smilies/spyder2.gif) 2010 RT 622 TRAILER TIMELESS BLACK
BRP trailer hitch, Utopia back rest, Baja Ron sway bar , heim links. Elka stage 2 shocks front and rear.
TricLed fender lights, saddlebag lights and mirror lights. LED headlights and fog lights, Wide vu mirrors.
spyderpops LED bumpskid ,zippered cargo bag linings, Laser Alignment by Netzleys Tire, Stebal air horn
stant gas cap,( Dimple oil plugs REMOVED ) JT dash mount.
(Onboard) Lamonster Garage air compressor and intelliboost charger.
Curious. ....
What spins..?? the actual plug or the wrench..?? If the plug is spinning you would be having an oil leak. Crossthreading on installation I have seen, many stripped allen heads and torx but not any plugs. If it is just the allen/torx you can cold chisel on the edge and get it loose or it you can get a visegrip on it.
![Quote](images/misc/quote_icon.png) Originally Posted by spyderryder53
Leon
You might have to take it to the dealer and have them install dimple magnetic drain plugs you will never strip them they are not Torx or Allens
![Quote](images/misc/quote_icon.png) Originally Posted by jtoro1
I have the dimple plug in there the plug spins won`t come out
Leon
AND
Did you install the Dimple Plug or did the dealer? The fact that it is spinning on the way out, means someone stripped it on the way in and left it hoping no one would notice.
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
Member: American Legion
Experience is recognizing the same mistake every time you make it! ![banghead](images/smilies/banghead.gif) ![](https://www.spyderlovers.com/forums/maps/map.png?states=SC.NC.VA.KY.TN.GA.AL.MS.FL.LA.TX.MD.MO.IA.SD)
![Quote](images/misc/quote_icon.png) Originally Posted by Chupaca
What spins..?? the actual plug or the wrench..?? If the plug is spinning you would be having an oil leak. Crossthreading on installation I have seen, many stripped allen heads and torx but not any plugs. If it is just the allen/torx you can cold chisel on the edge and get it loose or it you can get a visegrip on it. ![thumbup](images/smilies/thumbup.gif)
the plug spins I have a dimple plug in there but when I went to loosen it up it didn`t seem to tight but it just spins now and won`t come out or retighten treads must be stripped on motor.
Leon
AND
If it is the motor side wedge a blade between the plug and the case. Slowly loosen the plug. Hopefully it will catch and come out. Then you can helicoil it back to the original thread....
![Quote](images/misc/quote_icon.png) Originally Posted by Grandpot
I`m the guilty one here![opps](images/smilies/opps.gif)
Leon
AND
I assume the right side drain plug is the one with the 2 o-rings and one crush washer. This is only a guess based on your description but I would say that the drain plug sheared off at the base of the threads. Now the rest of the drain plug is being held in by the o-rings.
![](signaturepics/sigpic7798_4.gif)
Righty Tighty Lefty loosey! Either you or your Mechanic should write this on your wall. We have all made
this mistake. (except maybe Mike) ![Big Grin](images/smilies/biggrin.png)
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
not enough space to put anything in there tried that also put vise grips on so I could keep pressure on as I unscrewed it but nothing working
Leon
AND
Do you know which drain plug it is?
![Quote](images/misc/quote_icon.png) Originally Posted by billybovine
![](http://www.drainplugmagnets.com/images/310_IMG_0229.JPG)
the small one
AND
the small one
Well that's good news. You may not think so now.
Chupaca is on the right track. Get it out of there and a helicoil to fix the threads.
AND
![](signaturepics/sigpic9193_3.gif)
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
![](https://www.spyderlovers.com/forums/maps/map.png?states=AZ.CA.CO.ID.MT.NV.NM.OR.SD.UT.WA.WY)
Okay....
Leon
The dimple has a safty wire hole drilled in it. thread a strong wire through there with a long loop so you can put constant wieght while you turn the plug. The visegrips only give you a quarter or half turn. This way even if you crossthread it you will be able to get it out ...if not come on over I'll get it out.
The dimple has a safty wire hole drilled in it. thread a strong wire through there with a long loop so you can put constant wieght while you turn the plug. The visegrips only give you a quarter or half turn. This way even if you crossthread it you will be able to get it out ...if not come on over I'll get it out. ![Roflblack](images/smilies/roflblack.gif)
thanks I will give that a try
if it works I`ll have a drink for the both of us
Leon
AND
I went righty but to tighty when I put it in I guess ( used a torque wench but hmmmmm )
LEON
I have given up on "Torque Wrench's". I have three of them and they are all different. I try to apply just plain old common sense. It has worked well for so many years. People usually tighten too much. Good and firm has always worked for me for my airplanes, boats, motorcycles and cars. Never owned a Locomotive so no opinion there. ![shocked](images/smilies/shocked.gif)
Jack
2015 BMW R1200R LC
Did you mistakenly use 15 FOOT pounds with your torque wrench, instead of 15 INCH pounds?
AND
Have to agree...
But the biggest problem is that torque wernches are like prybars. Because they are so long they allow you to over do it way to easy. I have a bunch but the built in one work best. Not saying this happened to you Leon...
Yikes...!!
oh well that didn`t work ![don't know](images/smilies/shrug.gif)
Leon
Any further suggestions require some home made tools and some good luck. You may give the local dealer a shot cause they may have the tools... let us know what does the trick....
Time to pull the motor and start taking things apart...
Sent from my Nexus 6 using Tapatalk
