Results 1 to 20 of 20
    May 2016
    Texas
    Default Upgrade Speaker for my 2015 RT L
    I got plan to upgrade speaker for my 2015 RT L by JBL or Bose
    Any One already did it ? i need some ideas and i very appreciate that
    thank you , love you all so much
    I think that Mike (BLUEKNIGHT911) used JBL speakers...
    I'm switching to a full set of J&M speakers next Monday.
    Sep 2015
    Chilliwack, BC. Canada
    Default J & M Speakers
    I hope you will let us know how that turns out. I had J & M on my wing and loved them. Been thinking about them for my Spyder.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    May 2013
    Edmonton Alberta, Canada
    I replaced my front speakers with JBL GTO528's
    They are a 2.4ohm speaker and sound great.
    I had purchased a set of JBL GTO428's for the rear speakers being lead to believe that they would fit.
    The mounting holes do line up but the actual speaker is a good 1/4 to small leaving a rather large gap around the speaker which makes them sound like crap!
    I ended up buying a set of J&M speakers, 2.8ohm and I'm quite happy with the sound coming out of my machine!
    2014 RT-Ltd , Cognac
    May 2016
    Texas
    I checked on JBL website , model GTO 528 look like discontiued , any newest model will fit ??
    May 2013
    Quote Originally Posted by manman007 View Post
    I bought mine from ebay, there's quite a few sellers there to pick from.
    Active Member Synthetic's Avatar
    Aug 2015
    Springfield, MO
    I replaced mine with JBL GTO 528's....
    SoFlo
    JBL's in our 2014 RTS. I find it is a big difference.
    Post #6 in this topic
    http://www.spyderlovers.com/forums/s...light=speakers
    Default JBL , GTO - 528
    Quote Originally Posted by Synthetic View Post
    ....Since I think I had some influence in you getting them .......How do you like them ???.....Please give those who are on the fence some details.......Mike
    Jan 2015
    Flint Hill VA
    I am very happy with my JBL GTO 529/429 combination. Was able to install the 529s in front scraping knuckles through a tight gap behind the upper side panels (without removing the dash) Huge difference in sound at any volume
    Aug 2015
    Springfield, MO
    I can tell a difference in the sound between the original equipment BRP ones but not a huge difference. It was well worth changing over and would do it again. It's easy to tell the JBL GTO 528's are a lot better speakers than the originals...
    I had my J&M speakers installed yesterday...
    They definitely sound crisper and clearer.
    They don't seem to have the same Bass response as the OEMs; that's just a minor adjustment in the preferences screen...
    I call it an unqualified success!
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    There is a video of speakers install by finnless bob
    Active Member rays hell's Avatar
    Hiram Ga.
    Default JbL
    I replaced the OEMs with JBLs on my 13 RTs but was not impressed with improvement considering cost and labor.
    Imo the factory stereo just doesn't have enough output to drive the speakers.
    I think a 1oo watt or even a 50 watt amp for that matter would be a huge improvement.
    Monique,
    2016 F3t pearl white
    Ultimate driver back rest
    12v power outlet for batt. tender
    Doc Humphries' vibration damper
    factory floorboards
    added topcase
    May 2016
    Texas
    There are lots of JBL speakers .......which ones are you referring to ???????.........................Mike
    i got 528 on Ebay and they are on the way. let see how easy to hookup
    Bob, what size are the rear speakers ??????.............................How much were the speakers ????.......Thanks .....Mike
    These were direct replacements for the OEMs...
    They cost me about $170: I KNOW that you can get the JBLs for half of that...
    Member Robinson's Avatar
    Feb 2016
    San Antonio, TX
    Any suggestions as per:
    1. Where to get the pre-made adapters for the rear speakers?
    2. Can anyone donate a template (upload a PDF document) or required dimensions for those attempting to make their own.
    3. @PMK Can you provide further dimensions for the "1/8" Kydex plastic sheet" (links are welcomed!)
    4. Any suggestion as per what connector size/model are needed to avoid cutting factory terminals/wires (links are welcomed!)?
    5. Finally, any suggestions as per how to this WITHOUT dissembling of the whole vehicle?
    Looking into buying and self install the GTO 529 and GTO 429 pairs.
    Thank you to Bob Denman, PMK and everyone making our lives easier while saving some $$$ on these projects, I will see you @Texas Hill Country Spyders in the Hills, Boerne, TX - Oct. 13-15 !!!
    The J&Ms were a direct replacement. There was nothing else needed!
    Feb 2016
    San Antonio, TX
    Any specific J&M model suggestion/size?
    Default SPEAKER UP-GRADE
    Quote Originally Posted by Robinson View Post
    ."IMHO....My system is "KILLER"....It also has JBL's but not your model's ...... mine are 2 ohm the GTO series ....it makes a HUGH difference. If you are going to this do it RIGHT ... put 5.25" - JBL's in the front and REAR ( you need to make the rear hole 4 5/8 inches not hard ) get either 528's or 508c's.....Total cost for speakers is going to be less than $ 250.00 if you get the 508c's .....look on E-bay for the best deals ....................Mike
