Results 1 to 13 of 13
    Mar 2016
    colorado
    Default Where do I plug in battery tender to 2011 RT Limited?
    I've searched the forum and can't find any information. I am totally unversed in mechanics. I need to get a trickle charge on the battery.
    I bought the RT 2011 used a month ago. It has about 2200 miles on it and we're taking a big trip next month. I don't have a shop manual. It seems almost everyone on this forum knows how to hook it up, but I sure don't.
    All help is appreciated.
    Thanks.
    You can plug it right into the 12 volt power plug in the top trunk!
    On your bike: this plug is "hot" all of the time. Later models have the option of turning it into a keyed source of power...
    If you need a plug that'll work with your setup; Garmin sells them.
    Mar 2016
    colorado
    Thank you so much. I'm heading for the garage right now!
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    so my '15 doesnt work unless machine is running ? explains why my
    battery ran down while trying to program. i had the key on
    [with lights on] and my battery pack plugged in the back.
    so there is a fix.
    [joyce & irvin toms]
    In your owner's manual; there are instructions on which fuse needs to be moved, and where to move it!
    Feb 2012
    Spring City,Utah
    If you wish to learn a little about your machine, do a search on this site for finless' video on how to remove the battery,it's very complete. When you can see both terminals attach the cables from your battery tender to the battery posts and tuck the leads up under the seat. It is harder to write about then it is to do.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    On an 2011 RT, it is very simple, there are two terminals under the seat. One is covered by a red rubber cap that you can remove.
    Use alligator clips to make the connection. Instruction should be in your user manual.
    2018 RT LTD , Black
    May 2016
    mt morris il
    i was lazy and used the alligator hook too and ran the wires
    through the 12v outlet hole. cable tied it and done.
    Jul 2015
    north Carolina
    Having trouble with my 12volt adapter in rear trunk. No power. 2015 RT limited.
    Sent from my SM-G925V using Tapatalk
    Jul 2015
    north Carolina
    I could use some help thanks.
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    [QUOTE=nightshift357;1131332]Having trouble with my 12volt adapter in rear trunk.
    you have to move one of the fuses to a different position and then you could use the12volt cigarette lighter in the trunk to plug in your battery tender. I think the fuse is number 5 and 6
    Quote Originally Posted by nightshift357 View Post
    Look in your Owner's Manual:
    There's a Section in there that'll tell you which fuse to move, and where to move it...
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    I have 2015 RT. You need to move the fuse from position 6 to position 7 to have the rear trunk power on all the time.
    I installed an aux fuse block and have my trickle charger hooked to the fuse block that has power on all of the time.
