Results 1 to 24 of 24
    Springfield, MO
    Default New Lamonster Approved LED headlight
    We can't seem to keep the F3 LED lights in stock and we just brought in quantity of the same LED bulb for the RT headlight. Here's the details.
    http://www.lamonstergarage.com/9005-...for-spyder-rt/
    9005 LED Headlight for Spyder RT
    $109.95
    Product Description
    Price includes free shipping in the USA and includes two 9005 LED lights
    This 9005 LED headlight kit that is Lamonster approved. This kit will work on all current Can Am Spyder RT's. This is a direct replacement for the current headlight bulb. No moving parts to fail.
    From the ground up, this is the most superior LED headlight bulb you can install.
    Thermal “Air Flux Cooling” naturally draws heat out and away from the housing. No fans.
    Philips ZES LED’s that were designed exclusively for automotive LED headlight applications.
    Light point sources are identical to a standard 9005 bulb for full reflector splay.
    Pitch angle completely adjustable.
    Instant operation unlike HID. Unaffected by temperature or power cycling.
    Constant current power regulator in a separate housing makes the bulb no larger than stock.
    Zero noise induced into an audio system.
    Typically no trimming of the rubber boot required.
    Will not effect canbus or throw any codes.
    One kit includes the following; bulb(s) & power regulation unit(s).
    Element specifications (per element):
    6063 Aircraft aluminum construction.
    6000k color rendering.
    4000 lumen.
    360 degree light beam angle.
    24 watt per bulb.
    2.0amp (+/- .2) power draw. Stock halogen is 4.58amp.
    H4 connector for full plug and play operation.
    Default That's it....
    All for the F3 and the RT's....this could be construde as being bias..... /Great that sales are going well. Must be a good product and well accepted in the spyder community....
    Had I known that these were coming...
    (Filled the front of my RT, with TricLEDS bulbs last week...)
    Panama City Beach, FL
    i'd like to see a side by side installed comparison between the two. Just for fun.
    Sep 2015
    Mass.
    Do you have the led bulbs for the fog lights on an RT?
    Quote Originally Posted by DJFaninTN View Post
    How about if somebody shoots a video of them in a side-by-side flame-fest?
    Oct 2014
    Fort Mill, SC
    Thermal “Air Flux Cooling”... Is this done with a Flux Capacitor? When will I be when I land? Sorry, I couldn't help myself.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Springfield, MO
    I'll see what I can do.
    Quote Originally Posted by ttrac View Post
    I have some in route for testing.
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    Is there a big difference between the original and the LEDs?
    Active Member Tony8472's Avatar
    Gilbert, AZ
    Just bought a set for my RT. Thanks!
    Tony
    2014 RT
    Mods: Adjustable side wind deflectors; Adjustable vented windshield; Rear and front trunk lights; Replaced the foot pegs with Web Boards; Gerbing heater controls; Garmin Zumo 390LM GPS; Fog lights; Front headlamp accent lights; Replaced the standard fender light bulbs with LEDs; BumpSkid; Frunk insert and stripes from WrapMySPyder; BajaRon Swaybar; Laser alignment.
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    Quote Originally Posted by Lamonster View Post
    How about out an installation video as well. In the interest of time, perhaps just the install into the headlamp housing and the wire connections. I think most on the forum know no matter what you do on a spyder a lot of Tupperware needs to come off. Thanks!
    Ride safe!
    2022 Sea-T0-Sky
    Default OEM VS. LED @ 4000 LUMENS
    Quote Originally Posted by bscrive View Post
    If you are talking about a 9005 Halogen vs. a 4000 Lumen LED ......their will be a BIG difference ....especially in the color......The OEM is yellow the LED is White...........and the Halogen isn't even close to 4000 Lumen's, maybe 2500.............plus the LED uses about 1/4 or less of the power than the OEM.........Mike
    SoFlo
    If these put out quality beams at 4000 lumens they will be bright. That's 8000 lumens total for a pair of headlamps.
    My setup is 3200 per bulb so 6400 lumens for a pair of headlights. I also run 3200 lumens per fog light so 12800 lumens all up.
    The TricLeds per Tricled thier headlamps are 2880 lumens, I would guess the foglights are the same, so a pair of headlights would come in at 5760 lumens and 11520 for all 4 when lit.
    Last I read, xenon depot bulbs were 2500 lumens, so 5000 lumens on a set of headlamps and 10000 total for all up.
    Often people say it is not about lumens but about the quality of light given off. This is absolutely true. A very high quality LED with less lumens can be a better light than a higher rated led.
    If the lumens are high and the quality is excellent, this provides the best setup.
    Lumens do matter but are not always the holy grail, but consider lumens is sort of like watts from a home incandescent bulb. More watts is brighter.
    With 12800 total lumens for us, when lit and with purpose designed high performance LEDs, it is pretty intimidating to see coming at you.
    SoFlo
    Personally, I think a coal miners candle on a headstrap is brighter than oem. Around here I never felt comfortable at speed with oem bulbs.
    May 2015
    Oregon, USA
    Another +1 for an install video, or at least instructions.
    I really like the idea of replacing the headlights, but need to make sure that it's within my ability.
    Thanks! -Fratz
    SoFlo
    Quote Originally Posted by taxmyzer View Post
    The wire connectors should be plug and play. I heard some TricLed buyers had to swap the wires / polarity. I guess from what I read they stated Can Am had wired the Spyder incorrectly.
    On an RT, as for how to do the mechanical part, remove the mirrors, remove wind deflectors, remove small access panels, remove side panel body work, remove headlight surround bodywork, remove headlight aiming cable nuts, remove headlight, install LED kit. Reverse order to reinstall.
    Lamont will need to explain how or if these LEDs need the actual bulbs aimed since these have adjustments.
    If done correctly prior to the LED install, the headlight aiming should not change.
    Active Member juscuz's Avatar
    Dec 2015
    Virginia (US)
    Would be great to see an install video on a F3 also. Somebody please..
    Springfield, MO
    I'll be working on the F3 video next but here's the RT short version. If you can't remove the panels yourself then you might not want to try and install these yourself either.
    Springfield, MO
    Stock and LED side by side
    Jun 2015
    Union, Missouri
    Just curious.. Is this what you have to do just to change a burnt out headlight with a standard bulb? All that has to come off ?? I hope my headlight never goes out.
    Mar 2016
    Cheyenne, Wyoming
    Default No kidding
    Quote Originally Posted by dwade View Post
    I think I've spent more time pulling apart and putting together than riding
    Springfield, MO
    Yes it is but it's not as bad as it looks. The whole job could be done in 1.5 to 2.0 hours.
    Nov 2014
    Parkton, MD
    When will you have the LED Fog lights to go with these? I'd like to do both at the same time on my 2014 RTS.
    Jan 2011
    Apex, NC
    Default LED Fog lights
    When will you have the LED Fog lights to go with these? I'd done the head lights, they are great!!!
