Results 1 to 21 of 21
Thread: Gauges on RTL
    Aug 2015
    Canton, Ohio
    Default Gauges on RTL
    Somewhere in the forum there was a conversation regarding the analog guages being replaced and using the digital versions on the center display.
    i got excited for the possibility of using the slots for other purposes, but discovered my center group does not have the temp and fuel graphs.
    Is this because I have a 2013 RTL or do I need a software update that will put them on the screen?
    thank you in advance for all the learned experience that I get on this page!
    Joe
    Jul 2013
    Vestaburg Michigan
    I have a 2013 rtl , just unplug gauges. Then gas and heat bars will appear.
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    You have to disconnect the gauges and your digital will come up you could add a voltage gauge or anything else
    That's the way I have mine
    It might take a momentary "Leap of Faith" , but everything will work out fine...
    May 2015
    Upstate NY
    BOTH gauges need to be disconnected. You will find a single "free" wire and a plastic cluster of three wires for each gauge. Disconnect all of these on each gauge.
    The gauges on the 2014 are rock solid and I have not disconnected them. I disconnected the gauges on the 2010, and 2011 and went to digital. An easy fix for the non-mechanical.
    Aug 2015
    Canton, Ohio
    Quote Originally Posted by jtoro1 View Post
    AWESOME, I would love to put in a voltage guage in the round analogue holes, could I ask where to acquire such an item?
    Getting excited about this now.
    Feb 2013
    port st lucie fl
    Quote Originally Posted by Buckeye Bleau View Post
    EBay 52mm gauges
    Feb 2012
    Spring City,Utah
    There is a video on here by Bob(finless) on how to do this and the gauge he ordered. I bought the same gauge, though I think that is not available now but another similar is. I have enjoyed mine,but I was informed by my dealer when he changed my battery that it reads 1/2 volt low. Don't know if this is true of others or not but something to be aware of.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jun 2013
    Winchester, KY
    I got mine from Cruzer Joe.
    Bryant, Arkansas
    Quote Originally Posted by Brogers57 View Post
    I got mine from Cruzr Joe.
    Is it still working good?? I love mine and it has yet to fail.
    Cruzr joe
    Jun 2013
    Winchester, KY
    Yes sir!
    Invalid Emails
    Rotonda West,FL
    So what different choices do we have?
    Sent From my Note 5
    Bryant, Arkansas
    Quote Originally Posted by CapeSpyder View Post
    Sent From my Note 5
    Easiest and most popular
    Dual USB Plug & Volt Meter, from there, the sky is the limit
    Cruzr Joe
    Sep 2012
    Flushing , Michigan
    http://www.ebay.com/itm/131672724611...%3AMEBIDX%3AIT
    ToM
    Keep it simple
    Life is good
    Mar 2016
    Illinois
    Will this also work for 2015 RTL ?
    Jun 2010
    Las Vegas
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 This is a great looking voltmeter which we have installed along with this USB https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. For the USB you also need the black ring from JT's Machine Shop (spyderlovers sponsor)
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Bryant, Arkansas
    Quote Originally Posted by Jolvyc View Post
    Yes
    Bryant, Arkansas
    go with a digital voltmeter rather than the analog one, it is more accurate and looks better.
    Cruzr Joe
    May 2013
    Stanton, ca
    Feb 2012
    Spring City,Utah
    Bob have you checked your volt meter lately? When I had my battery warrantied the dealer said mine was reading .5 volts low.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
