Results 1 to 14 of 14
    Invalid Emails
    Oct 2015
    morgantown west virginia
    Default frunk power port/or lack of
    I thought the 2012 RTS was supposed to have a power port in the frunk?
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Quote Originally Posted by quasi View Post
    Only in the back trunck
    Nov 2015
    Chardon, OH
    It's an accessory kit available to install...at least I think it's still available. Check on it if you want one. If you look up under the left side bodywork towards the top of the left front shock, you'll see a wire harness that ends with a rubber boot. The outlet installs in the frunk and connects there. The wire connectors in that rubber boot are always energized on the 2012. I never installed that outlet, but I did seal up the opening in the boot to keep out dirt and grime. The outlet in the rear is always on, on the 2012 also.
    Doug
    ”Freedom is not a loophole”
    Invalid Emails
    Oct 2015
    thanks, good info
    Apr 2013
    Somersworth, NH
    I ran some wires from that rubber boot and installed an outlet on the dash.
    2016 RT-S Special , 2 tone black
    It's still available as an accessory...
    Nov 2015
    Branson MO
    Default outlet
    Does this info apply to the 2011 as well?
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by Freezedryman View Post
    Yes
    Part number: 219400366
    $32.99
    This will fit ALL RTs...
    May 2015
    Barryville NY
    Default usb in frunk
    I used this one in the frunk part # 219400510 $34.99 . It give you 2 usb ports in the frunk. It just screws in like the 12v port and the wires hook right up to it. It's for under the seat for an f3 but fits perfectly.
    Active Member CharlieIndia's Avatar
    May 2011
    Washington Pa.
    Where is the rubber boot on a 2015 RTS to install a plug in the frunk can't seem to locate it?
    Sep 2014
    USA
    Quote Originally Posted by CharlieIndia View Post
    Standing in front of the bike next to the battery cover on the right is a plug. Behind the wall of the frunk is the boot and wires. They are wire tied together..
    May 2011
    Washington Pa.
    Thanks, found it
    Linden, CA
    You can get one with the wire and fuse at Cycle Gear for $12.00
