Page 4 of 4 FirstFirst 1234
Results 76 to 88 of 88
  1. #76
    Wellsville, NY
    I now have everything except the hydraulic hose line. I know that it has to have a banjo fitting on the master cylinder end. Probably a 10mm to fit the one I have. What do I order for the slave end. I have the same red one that was ordered on ebay. What is the fitting called size etc that I should order on the line? If I could find a custom shop that would put a banjo on one end and reduce to a 3/16 tubing on the other end, I could just use the 90 degree fitting I have and I would put a double flare on the end of the tube after sliding my fitting over the tube. Any information on what or where I can order would be greatly appreciated.
  2. #77
    Mod Maniac
    May 2008
    North Texas
    Quote Originally Posted by Magnum Force View Post
    JPCycles.com has pre-made hydraulic lines with different end fittings. If you know the length of the line, go there.
  3. #78
    Mar 2010
    Stow, Ohio
    Default Hydraulic Hand Brake
    Quote Originally Posted by Putt-Putt View Post
    I would really-really like to do this hand brake thing. But I don't want to get in over my head. I wish someone would make a kit for it.
    Someone does. Check the ISCI handbrake. It's a little pricey at $1250 but with something as important as your brakes, it's worth the expense. I installed it on my 2010 RT and have not been sorry.
  4. #79
    Invalid Emails
    Mar 2008
    Spooner, Wis.
    Quote Originally Posted by Bootie View Post
    Thanks for the info.
    Yes I know about ISCI. And I'm sure they are very good. But the price is just ridiculous.
  5. #80
    Apr 2010
    Milehigh City
    Default Good Job
    Nice writeup Nexus. I like this alot.
  6. #81
    Jun 2010
    Earth
    anyone get the Brembo & 7/8ths slave cyl to work better??
    seems that there should be less fluid volume in the slave so it would get pushed further/faster?
  7. #82
    Active Member 3Willie's Avatar
    Cape Girardeau, Missouri USA
    Default Cable Hand Brake
    My cable driven hand brake works great with about $60 worth of parts and my time to manufacture brackets. Several people have commented that the hand brake lever pulls pretty easily. It works in conjunction with my foot operated handbrakes so I can use either foot, hand or both brakes at once. Much of the effort to pull the brake lever depends on the angles where the brake cable connects to your bracket near the master cylinder. A straighter pull will usually work best in my experience. I also made the holes that cable fits into a little oversize so there is room for the cable to seat properly and move easily. I also used a clutch perch and lever (instead of a brake lever) which allows quite a bit of cable adjustment near the handlebars.
    I have been using sewing machine oil to lube my cables. It is a very high quality oil with a precision type applicator. So far, the oil does not seem to be attracting dirt or grime and really lubes up the cable. I do not think it will degrade the inner lining of the cable either or at least I hope it doesn't. It seems to work good in sewing machines which have a lot of dust from thread and cloth, so figured it was pretty good stuff and should prevent wear.
    I usually do not brake too hard if at all possible, but think I could lock up the brakes with a quick pump on my hand brake cable system. During harder braking, I seem to use both foot and hand brake just like on my previous two wheel bike. Bottom line is that brakes are nothing to do half way. That is usually why aftermarket brake stuff is so expensive. Not only the research, but the liability for the products cost a bunch. It seems to cost a lot of money to keep us from hurting ourselves (or litigating).
    Before you ask, I did not take pictures while I was working up my bracket and cable hand brake system. I will try to get dimensions, photos etc the next time I have the plastic off. I may also post a picture of the bracket with dimensions so you can make your own. As several have noted, the area around the master cylinder can be a challenge to work in, so not anxious to take apart just for fun. Seems that it would just be a given to have a factory offered hand brake, but guess we will just have to work around that until one is offered.
  8. #83
    Invalid Emails
    May 2016
    NW Washington State
    Default Slave cylinder
    For anyone interested the slave cylinder I found is from Coleman manufacturing part number 375-300. This place has them http://www.scpraceparts.com/billet-a...-cylinder.html as well as many others. I found one cheaper. Figuring a hand brake conversion to run around $300 with some bracket fab time thrown in.
  9. #84
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    Quote Originally Posted by Habib View Post
    Funny you bringing this thread back today as I've just completed this mod myself and posted about it here:
    http://www.spyderlovers.com/forums/s...46#post1125746
  10. #85
    Invalid Emails
    May 2016
    NW Washington State
    Thanks for the link to your write-up. I found a few different ones but not yours. After reading it and looking at the pics I learned even more. The tip on the slave cylinder supports was a good one, thanks. To bad all versions of this particular write-up can't be in one spot. So many of us can't use our right side well enough to operate that foot brake.
    Cheers,
    Roger
  11. #86
    Oct 2013
    Broken Arrow OK
    Default hand brake information
    Cheers,
    Roger
    Has anyone updated this post or started a new thread with new information. I would really like a hand brake and I feel like many, ISCI is pricey and not in my budget. I would like to put one on my 2012 RT and need all the help I can get.
  12. #87
    Quote Originally Posted by wlo48 View Post
    look at post #88 above and follow the Link listed ….. Mike
  13. #88
    Jun 2020
    Texas
    I’m a C7 quad . I just got a 09 spyder. I need to put a handbrake on it since I can’t use my feet. Any help will be greatly appreciated. I’ve seen the one for sale for almost 1500 bucks. Please if you could pm me or tell me a cheaper but safe way to put a handbrake on tia
Tags for this Thread
