Results 1 to 20 of 20
    Dec 2012
    Greece
    Default How to unlock front trunk with out key
    Ok shut down front trunk and my keys in it. So how to you get it open with out the keys?
    Nov 2012
    North Las Vegas, NV
    A long straight stick or screwdriver from the left side under the frunk lid to the latch. Push on latch, should pop.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Default There you have it....
    many have done this and many more than once... some have put a secondary pull cord hidden for such occasions...
    Dec 2012
    Greece
    Thks all got done for shure. Thks for your help
    Dec 2012
    Greece
    I did put a small cord and it works great. Tuck it under weather strip can't see it at all
    Oct 2011
    Jacksonville,Ar
    I had a locksmith make a key.
    It will only open funk and lock the trunk.
    Under $5.
    15 rt , yes Black
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    FWIW - when I owned a Piaggio their forum described the method for opening the seat without the key. Then folks started having their scooters broken into by thieves who read the method.
    Their solution was to stop posting and send a PM only to registered members with a specific minimum number of posts. The thefts were reduced, particularly after the moderators removed old posts describing the method.
    Something to consider here? We may think it's obvious how to access the trunk, but how often the question gets asked tells me it's not so obvious. So why advertise it?
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    I agree that's the greatest idea anybody has come up with I put one in
    Mar 2015
    forrest above Reno, Nv
    Thumbs up How about a picture????
    Quote Originally Posted by Spacetrucker View Post
    I looked and didn't see a good place to attach a cord. It seems it would get tangled in the lock mech as you have to pull it to the drivers right to open the frunk. A pix would really help.
    Also I don't see how a small stick or a long screw driver is going to work with out scratching the h&ll out of the frunk.
    Any thoughs and pix are much appreciated
    Kaos
    2014 RTS , Circuit Yellow
    Invalid Emails
    Oct 2015
    Deland, FL
    Default Extra key
    I keep a second key hidden in the trunk and have a key in my wallet that I can always use to unlock the trunk and get the second key.
    A blank to release the lockables is an Ilco X270. I had to bevel the key as shown so it could be pushed down far enough in the ignition switch to release the frunk and seat latches. I keep it in my wallet.
    Bossier LoUiSiAna
    Same here I try to keep some spare blanks if I meet other spyders that want to do the same. (I didnt have to bevel mine thoż)
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by kaos View Post
    Kaos
    I put a wire to the riders left and it comes out under the oil check panel on the 2012 RT. You have to lift the left corner up to insert the rod or stick. Shouldn't scratch anything.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Nov 2012
    North Las Vegas, NV
    Here are some pics, you have to run the rod right down the channel. If you take off the black inspection panel you can run a wire across to the left.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Sep 2014
    USA
    Man I am surprised we are giving out how to break into our bike information to the free world..
    Sep 2014
    USA
    Quote Originally Posted by MisterP View Post
    Nov 2012
    North Las Vegas, NV
    Really? A non owner couldn't start one with the key.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Sep 2014
    USA
    Yes.You are correct from a certain way of thinking, but if someone wanted your Spyder they will get it.
    I was referring to the unlocking the trunk/frunk.
    Mar 2015
    Thumbs up Thank you
    Thanks guys,
    With the inspection removed it was all very easy. Used a strong nylon string with a large ( 1.5" dia) rubber washer tied to the loose end and tucked away but I can still get to it.
    Kaos
