Midland transmit problem
2014 rt limited...just install midland cb75-822..sr10, sm10, smh10 duel...the first press on the CB's ptt button transmits to another CB, but it won't let me transmit again for about 10 seconds...sena tech told me to Do a factory reset on the SR10 and pair them up again to the headsets, it didn't help..any ideas??
Midlland CB
Try bumping the ptt button two quick times and see if that doesnt turn the sr10 off.
Tried two quick button pushes...still doesn't transmit after the first push for 10 seconds ..thanks
2014 RT Limited Midland CB...SR10, SM10,SMH10 duel...JB antenna
Midland CB
I dont know if you have tried this, but you have to pair the sr10 and phone in the correct order. If you dont it causes trouble. Just checking.
Im not using a phone in this set up...just the CB, intercom and stock radio..no other audio devices...
