Page 1 of 3 123 LastLast
Results 1 to 25 of 52
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Default Looking for the RT Vent Kit instructions
    Just picked up a RT Vent Kit for our 11 RT and it didn't come with instructions. By chance does anyone have any? Any tips on this installation would be greatly appreciated.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Mar 2011
    Jackson, MS
    Found the instructions, am I just suppose to install the vents? Are there any additional items i should be removing?
    Quote Originally Posted by M109Dreamer View Post
    You'll probably want to remove the acoustic panels to give better air flow to the engine compartment. The stuff about the fuel system is specific to the 2013s.
    Active Member Doc - Riverside's Avatar
    Jan 2010
    USA Folkston,Ga
    Resent you the PDF document that will show you how to install the vents on your RT without the need for the template called out in the 2013 recall instructions.
    Apr 2013
    Monument, Colorado
    Where did you pick up the vent kit from??
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    If you do a search for Doc Riverside, he has a complete rundown of the installation and where to get the vent kit at the best price. If I can find the link, I'll post it here when I do, and we just did the install on two 2015 RT's and they look like they came from the factory. Here's the link: http://www.spyderlovers.com/forums/s...ght=side+vents Good luck.
    David
    Mar 2011
    Jackson, MS
    Quote Originally Posted by Doc - Riverside View Post
    Thank you, apparently I lost the previous email.
    Quote Originally Posted by Empty Pockets View Post
    I picked them up at the Can Am Dealer in Greenville, TX. We were on a ride and stopped by and thought I would see if they had them. They actually had 3 sets in stock. If you are needing their info shoot me a PM and I can look it up.
    Quote Originally Posted by Devious56 View Post
    If you do a search for Doc Riverside, he has a complete rundown of the installation and where to get the vent kit at the best price. If I can find the link, I'll post it here when I do, and we just did the install on two 1025 RT's and they look like they came from the factory. Here's the link: http://www.spyderlovers.com/forums/s...ght=side+vents Good luck.
    David
    Thank you
    I appreciate the help y'all. Now it looks like i need to do some reading and laying out the plans.
    Shane
    Aug 2017
    OK
    I tried to send the following message to Doc - Riverside, but getting error message - Sorry gstwt60 you must have 1 posts in order to send PM's. I normally don't post anything, instead prefer to search if there is an existing thread already with the information.
    I'm looking to install the Can-Am Spyder Rt Vent Kit 219800388 and per the forum it looks like you are the guy to go to for installation instructions. I tried to see if there was a link with the instructions, but have not had any luck. Do you still have the installation instructions and in your opinion would they actually help with a 2011 RT model?
    May 2018
    Chateauguay, Qc, Canada
    I just installed the kit on my RT. I have the BRP instructions that include a lot of other stuff. I can send them to you if you like. PM me with your email address.
    A note for Canadians who might be reading this. I ordered my kit from a CanAm dealer in Canada, where I live, and it was cheaper that buying a US one.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    May 2013
    Maryland
    Hey everyone, Need help on how to install the Can-Am Spyder Rt Vent Kit. I looked every where and I can not find any direction on how to install it. Any help would be appreciated.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by kajazzman View Post
    See post #6 above
    2014 RTL Platinum
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    I got lucky, these were on my '14 RTS when I got it. need to figure out how to remove them to do work now....
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    May 2018
    PM me with your email and I can send them to you.
    Eckhard
    Spyder RT Ltd, 2011
    Quote Originally Posted by Wahrsuul View Post
    Look close for a couple of plugs in the vent. The screws are under them.
    Dec 2015
    Oakley Utah
    They're attached to the body panel. Remove the body panel.
    2014 RTL Platinum
    Aug 2016
    Nashville, GA
    Doc Riverside, it is good to see you back on Spyderslover again! You have so much helpful knowledge that your assistance is greatly appreciately! Your friend, Marshall
    Mar 2019
    Central SC
    So I don't need to remove them to get the body panel off?
    2014 RT-S , Orange
    Dec 2015
    Oakley Utah
    No. They're attached to the body panel
    2014 RTL Platinum
    Jun 2019
    jstreet
    Sorry to chime in... I started to look (and found) the RT Vent kit. Some sites say send in vin# one site (bike bandit) says all RT models... Mine is 2012 RTS SE5... Should I pull the trigger and buy?
    2012 RTS SE5 , Spider Web Brake pedal Orbital blue
    Apr 2018
    Kentucky
    I installed these last year on my 2012 Rt, very easy to do. it really makes a huge difference in the air flow and really lowers the temperature in the engine compartment.
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Interested in them, but, for physical reasons, can't install them. Got a quote from the dealer for 1 1/2 hrs. labor. Sound about right?
    Nov 2018
    Claremore, Ok.
    There are 2 screws, one in each vent just before the mesh that need to be removed, then remove the panel like you normally would. The vent assembly will come off with the panel. Mine didn't come with instructions either. I fiddled with the pieces until they went together then figured out how to install them. I put the panel on my kitchen table and fiddled some more. Marking where to drill the attachment screws can be a bear. I missed a couple and needed to drill new holes, but the vent covers them. I didn't cut out the panel, just removed the stock grill and it performs as expected. Now I can put candy bars in the glove box and they don't melt. Pete did sent pics of how he did his. Thanks Pete.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    Quote Originally Posted by Revalden View Post
    The instructions call for you to cut the opening larger. If you leave them with the original opening, they wont flow nearly as much air.
    2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
    2010 RT SE5 , Black
    Sep 2019
    Philippines
    Quote Originally Posted by Eckhard View Post
    PM sent.
    Jun 2019
    Farmingville
    Need instructions please for my 2010 RT
    2012 RT-S SM5 , Pure Magnesium Metallic
