Results 1 to 8 of 8
    Sep 2012
    Louisburg, Kansas
    Default Question again on our new 1330 RT-Limited
    What a step up from the 998---and 2012 RTS-SE5----Already put 78 miles on in one day here- and it wasn't even that warm out to ride. More fun to come along.
    We did have a question---in the TRUNK- what in the world is that little shelf like thing that is attached with velcro on the top and on the bottom for? the bottom has a stitched piece of leather holding it on to the velcro there. We can't figure out what it is- or used for?
    Can someone shed some light on that one?
    Really like the changes we are seeing. So far so great!
    Thanks for your help in responding to our inquiry!
    2015 RT-Limited SE6-TricLED Fender LED's (Red and Amber), 3rd LED Brake Light/Tail Light, ISCI Handbrake with black small hands handle,Spyderpops Rock Guard. ,Can-Am Adjustable Wing Vents, Bumpskid, Bajaron's Sway-Bar with metal Heim Joints. Elkas Stage 2 Plus., TricLED Wide-VU Mirrors, TricLED Jumper Port, Laser Aligned!
    Elembytes, That 'little shelf like thing' is just a potentially helpful organiser come tray for the trunk... With it in the raised position, ie stuck up on the Velcro at the top, it will hold a notebook or two, maybe a slim wallet or vial of eye drops... And if you clip the straps that should be fitted to the sides of the trunk down at the same level as the base together so it has something to rest on when hinged down on the strip of leather, you can fold the shelf down so it forms exactly that, a shelf that'll stop all the stuff you want handy from falling down into the guts of the trunk - or it can form a base for the trunk bag (optional luggage item) to rest on.
    Enjoy!
    on your new 1330. It really is night and day difference from the 998.
    Sep 2014
    Northern California, US
    As Peter mentioned, it is mostly a trunk "organizer", although I don't find it that helpful. If yours has the cig lighter and the audio connection in the trunk, the trunk can serve as a place to rest items plugged into those ports while riding.
    The good news about the rear shelf: it's easily removed!
    Stick a knife blade under the adhesive that holds it to the back wall of the trunk, and start peeling!
    I've left mine in place for the sole purpose of giving the top trunk's luggage case a place to sit.
    Feb 2016
    HAWTHORNE nj
    Default shelf
    Does all RT s come with this shelf...
    No; it's only standard on the Limited model.
    Jun 2014
    People's Republic of NY
    https://www.youtube.com/watch?v=QwaZ...ature=youtu.be
