Results 1 to 17 of 17
    Dec 2015
    Fairfax
    Question GPS install for 2015 RT S Special Series
    Can someone provide info on the best avenue to install a GPS on my Spyder? I called a dealer and they quoted a price of $1300.00 for the parts and installation. That seems a bit steep. Any information is appreciated.
    Mar 2015
    Brockport, NY
    Default Your only limited by your imagination
    There are many many options for GPS. You can buy the dealer one, pricey as you noted. You can look into a non can am motorcycle model and secure it to the console in a bunch of different ways. There is the smartphone app route. I went with an iPad mini that I already had, added a bad elf GPS unit to it for $89 and bought the TomTom app for $19.99. Uses no data and also connects via Bluetooth to my helmet so I can hear the turn by turn if I desire. I have a freezer bag ready in case the weather turns bad.
    2014 RT-S Pearl White
    Default GPS OPTION
    Someone posted ( last week ) what appeared to be an incredible GPS, that was waterproof etc. had a built in shade....and was soooooooooooooo reasonable in price ( about $132.00 ).....I know Murphy Brown bought one ....perhaps she can give you the LINK.....OK the thread " GPS " was started by " rtga ".....0n 2 / 23 /16.......Mike
    Active Member rays hell's Avatar
    Hiram Ga.
    Default mount
    As far as mounts go I really like mine from JT. [A sponsor on here] It puts it in a good spot above the dash.
    It also provided a good spot for my magnetic Siriusxm antenna. win win.
    Monique,
    2016 F3t pearl white
    Ultimate driver back rest
    12v power outlet for batt. tender
    Doc Humphries' vibration damper
    factory floorboards
    added topcase
    Jan 2015
    Outside L.A.
    why even mount it, just plug your phone into the sound system, or bluetooth to your helmet, and she will guide you wherever you want to go, all for free.just my thought.
    Feb 2012
    San Jose California
    Default Spyder GPS unit
    Please check this Motorcycle waterproof GPS (entertainment system).
    http://www.zoozmc.com/#!product/prd1...5.0%22-zg-5060
    We have a special mount for Spyder RT.
    You can check some of the advance feature here .
    Feel free to contact me on any question you may have.
    Jun 2014
    People's Republic of NY
    Mar 2011
    gaines Michigan
    Can anyone show how to run the wiring harness for a gps on 2015 rt?
    Apr 2015
    Lodi WI
    Default My GPS mount and ram mount
    1st picture is my view while riding. I'm 5'8". The temp guage is somewhat obstructed while riding but viewable. 3rd picture is my $40 Ram mount from Amazon. Really holds the phone nice. I screwed the device with small bolts and nuts to the bike. http://www.amazon.com/gp/product/B00...ilpage_o08_s00 I ordered both accessory items in the Amazon page. 2nd picture is how I screwed the suction cup to my dash. Our three wheelers have this side to side motion that made the GPS wobble on rougher roads. I made a simple black plastic brace in the upper left corner of my original post picture. The end result is my GPS is rock solid and does not move at all even on rough roads. 4th picture is a general side view of my dirty bike and garage. You would think with it being winter and having a heated garage I could find the time to detail my bike. I suspect a lot of riders are not comfortable with making holes in their bike for accessories. If I sell this bike the GPS and Ram mount would stay with the bike. Truthfully, of the many bikes I have sold with various cobble jobs to them, not one buyer has ever mention these types of alterations.
    Dennis, Close to riding, near Chicago Here is the GPS link. My pictures of my GPS are in full sunlight and you can easily see the screen.
    http://www.aliexpress.com/item/2015-...429371041.html
    Sep 2014
    USA
    Quote Originally Posted by ijon1 View Post
    You want factory hookup? if so its under the seat right side panels come off and connections are there for stock GPS setup.
    If not I am sure others will chime in on there setups
    Mar 2012
    Beaverton, Oregon
    I like the JT mount also.
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Sep 2014
    USA
    Same as a 2014 install using the BRP optional kit. It was not inexpensive, but does include all the mounts, wiring and stuff needed to install the GPS, plus included a lifetime map upgrade GPS.
    The right side panels do need to be removed, the connections are just aft of the fuel tank and the audio jack is on the side of the fuel tank. The more difficult portion is routing the wires down from the handlebars. I almost recall, removing the let side upper panel and the headlight bezel, plus the right headlight to make it easier. Could be wrong though since it has been a while. Not a difficult install, more simply time and patience.
    You are correct. The hardest part was getting the wires down thru the handlebar area
    Mar 2011
    gaines Michigan
    Thank you all for your help.
    Dec 2010
    Telford, UK
    In early 2011 I produced a plan hereabouts which I'd used for my own GPS installation called "Mounting a Zumo Up High". It came with a photo step-by-step-how-to and was well received. It is still available on the DIY forum board, though by now it's about 5 pages back.
    FWIW, I included the dealer installation of a Zumo 590 in the deal package for my 2014 RT-S. Yes, it was more expensive than other options but that's the way I wanted my new Spyder. I am very comfortable with it on the OEM mount for the Tri-Axis bars and the wiring run is inconspicuous and direct. See the picture
    Port NEches, TX
    Default Did you ever install
    Quote Originally Posted by tonydenham View Post
    Did you ever get a GPS installed onto your byke?
    Feb 2012
    San Jose California
    Default GPS on a spyder
    You can install this entertainment GPS system on a spyder in few minutes.
    http://www.zoozmc.com/_p/prd1/359361...5.0%22-zg-5060
    We have a special Can Am adapter that is very easy to mount, in addition this unit includes an FM transmiter that can transmit the music and GPS instructions into your sound system so no wirering is needed except for power.
    Quote Originally Posted by RedRTS View Post
Tags for this Thread
