Results 1 to 24 of 24
    SpyderLovers Sponsor scooterexpress's Avatar
    Mar 2012
    ft-worth texas
    Default can fuel injector cleaner be used
    the reason I ask is I had some fuel that was in the tank sitting there not even running the bike and I notice that when idling it wants to shutdown and after riding some I notice a little hesitation was thinking maybe I should use some fuel injector cleaner to get the gum out so to speak what you all think its a 2011 rts..no I haven't replaced spark plugs as of yet has only 20k on it but i'm sure its do but thinking of trading in this year.just looking for feedback or suggestions
    ty,
    jim
    Tall flag mount, spyderpops skid plate & stainless steel screen mesh, airhawk adjustable cushion, raised white lettered tires.
    Nov 2012
    North Las Vegas, NV
    You could put some Seafoam in the gas. If it still doesn't run right the vacuum hoses on the throttle bodies could be bad. If the spark plugs have not been changed (due at 14,000) that could be it, also the spark plug wires go bad from the heat.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jan 2015
    southern WI
    I'm also a fan of Seafoam for this kinda thing. I use it in everything I own. It works well for seasonal stuff when it's "brought out" for the first start-up. It also does a good job as a maintainer I think. A few ounces in the tank every few tanks. It doesn't take much
    2016 RTS , Pearl White
    South Okanagan, BC, Canada
    Another vote for Seafoam here. Great product.
    Gary
    Dec 2015
    Galax VA
    Ditto on the Sea Foam. It's good but personally I like this stuff better. I also do not run gas with ethanol in any of my small engines or in anything that sits for any length of time because the ethanol absorbs moisture from the air and it eats rubber. Your results may vary.
    https://www.google.com/?gws_rd=ssl#q...jector+cleaner
    Sep 2014
    Los Angeles
    Run Sea Foam in my Motorhome
    Another Day To Be My Kid's Dad [emoji379]
    Bossier LoUiSiAna
    When you can use Ethanol free gas as well.
    http://www.pure-gas.org
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    Default Good question
    This is a great question. I had never heard of Sea Foam until I read all the positive comments. I just ordered a gallon jug of it on Amazon.
    Thanks for posting a very useful topic.
    Pam
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    I agree the vacuum hoses are junk use silicone hoses
    Throw another vote on the pile for Sea Foam, new plugs and wires (contact Ron...), and new vacuum lines...
    Active Member Grayfox's Avatar
    Nov 2012
    Advance n. c.
    I use Sea Foam in every thing no matter what gas I use.
    Quote Originally Posted by Grayfox View Post
    You just HAD to mention gas...
    Spam, onions, and hash for dinner...
    Dec 2015
    Galax VA
    Beer, Pickled Egg's and Peanut Butter.
    Thinks out loud
    Apr 2012
    Arrow Contrarian
    Good old MMO, been using it for years and in the 2011 Spyder for almost five years. Sometimes, old is good.
    Default I'm in....
    Sea foam works for me. Don't have the standing gas problem but have to deal with the ethanol. ..
    Quote Originally Posted by Sam Mac View Post
    I am SOOOOOOOOOO..... jealous right now!!!
    Mar 2015
    forrest above Reno, Nv
    Default Savers
    Quote Originally Posted by Pampurrs View Post
    Pam
    Pam,
    You have saved about 15 cents per ounce of Sefoam ( which I have used for years). I do find the convience of a small can easier to handle than a gallon jug. Guess you could use a really small funnel to facilitate the transfer.
    I didn't know Seafoam was sold in gallon jugs and am considering it.
    Kaos
    2014 RTS , Circuit Yellow
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    I used the small squeeze bottles from the dollar store. Come in packs of 3. I just put 5 oz of seafoam in it and take it with me to the gas station. Then I just throw it away when Im done.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    washington state
    Seafoam is used in boats, cars, and MC including .
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by kaos View Post
    Pam,
    You have saved about 15 cents per ounce of Sefoam <snip>
    Kaos
    128 x .15 = $19.20
    Just sayin'
    Pam
    Apr 2012
    Arizona
    I thought with fuel injectors you did not have spark plugs! Guess I'm way behind.
    Feb 2016
    Atlanta Ga
    Quote Originally Posted by jerpinoy View Post
    I hve a bottle of Lucas oil I bought for my car. Is that good go use for the bike?
    Quote Originally Posted by MrBones View Post
    That would be diesel engines that lack spark plugs... and they pre-date you!
    SoFlo
    Sea Foam in the cars and pick up. Good stuff in that application.
    I use Yamalube Fuel Med RX in each tank of fuel. Stops separation of the fuel and prevents corrosion.
    If you ride a lot and go through fuel quickly it may not be needed, but as somewhat of weekend warriors, sometimes for different reasons the Spyder may not get run every weekend.
    I have posted about the Fuel Med RX before, so a quick search should find more info.
    Honestly, whether you run pump fuel or non ethanol, it is cheap insurance to add something. Cars are much less finicky than a motorcycle with FI.
