Results 1 to 11 of 11
    Active Member sjcpanther's Avatar
    Mar 2013
    Advance, NC
    Default Driver Backrest for 2014 RT
    Looking to purchase a driver backrest for my 2014 RT-S. Really don't want to pay $450 for the Can Am rest, so I'm looking at some off brands.
    Wasn't sure if the off brands would utilize the same mounting through the existing OEM seat or not.
    Have any of you guys purchased an off brand that works well with the OEM seat with no other modification involved?
    2014 Cognac Spyder RT-S SM6, purchased July 8, 2015
    Rivco Flag Holders
    Eduo Innovations SRT Clear/Stainless Cup Holder
    Lamonster Spyder Decals
    Inspector Gadget Driver Floorboards and Heel-Toe Shifter
    Sena SPH10H-FM Headset for Half-Helmet
    Hopnel 1500 Front Trunk Liner
    BRP Trailer Hitch and Control Module
    2014 Escape Trailer (Black and Diamond) from 1 Motorcycle Trailers
    2012 Magnesium Spyder RT SM5, sold on July 8, 2015
    Default BACKREST
    ....I've had Utopia's on a few Motorcycle's including my Spyders and they are the best for all reasons , imho........Their attachment bracket, is the same as BRP's and fits EXACTLY the same...........I bought a used Utopia on E-bay and made my own Bracket...............Mike
    Mar 2013
    Advance, NC
    From what I can tell, the BRP backrest doesn't require any brackets. Just pop the seat tab off and push into the seat. No bracket necessary.
    Do aftermarket brands work this way or do the need to have a bracket installed under the seat?
    Rivco Flag Holders
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by sjcpanther View Post
    OK. So I assume that just because I have the hole in the OEM seat for a backrest, that doesn't mean that I have the bracket, correct?
    So whatever backrest I get will come with the brackets necessary, and I'll need to mount that under the seat.
    Am I correct in this thinking?
    The Utopia backrest comes with everything you need to install. All you need is a serrated bread knife and a little cutter to notch out the little plastic cover that's over the hole in your OEM seat.
    It's a very easy install.
    Go on their website and look at the installation directions to see for yourself.
    2020 RT Limited , Chalk
    Default BRP - BACKREST
    I seem to remember someone here bought one from another member, and only received the actual Backrest....later discovered they needed the Bottom Bracket to hold it to the seat Pan...........maybe someone here that has added one will clarify.....if not go on the BRP accessory catalog and see if they tell you......Mike
    Nov 2010
    Tyler, Tx.
    I had a Utopia backrest installed on our 2010 RT-S SE5 in November 2011 and have been very happy with the decision.
    Reese
    Mar 2015
    Brockport, NY
    Default There is a bracket
    There is a bracket that comes with the brp backrest. I installed mine last year, purchased from a fellow Spyderlover member and am quite happy with it. I actually just reinstalled it into my seat after adding the adjustable backrest add on that brp came out with. I'm looking forward to taking it for a little test spin to get it dialed in.
    2014 RT-S Pearl White
    Oct 2011
    Mapleton MN 56065
    Default Utopia backrest
    I just installed this Utopia backrest this past week, am extremely satisfied with all aspects! Easy install, all necessary components supplied, perfect color match, adjustable fore and aft, folds down flat, excellent price.
    Bob at utpr.com
    Brent,
    I'm interested to hear about your experience with the new adjustability; please let us know about it...
    Thanks!
    Mar 2015
    Brockport, NY
    Default I'm excited too
    Brent,
    Thanks!
    Absolutely, might be a few weeks however before the salt is rinsed away.....
    It appears that we BOTH are playing the same, "waiting game"...
    Good Luck!
