SpyderLovers Sponsor
can fuel injector cleaner be used
the reason I ask is I had some fuel that was in the tank sitting there not even running the bike and I notice that when idling it wants to shutdown and after riding some I notice a little hesitation was thinking maybe I should use some fuel injector cleaner to get the gum out so to speak what you all think its a 2011 rts..no I haven't replaced spark plugs as of yet has only 20k on it but i'm sure its do but thinking of trading in this year.just looking for feedback or suggestions
ty,
jim
Tall flag mount, spyderpops skid plate & stainless steel screen mesh, airhawk adjustable cushion, raised white lettered tires.
You could put some Seafoam in the gas. If it still doesn't run right the vacuum hoses on the throttle bodies could be bad. If the spark plugs have not been changed (due at 14,000) that could be it, also the spark plug wires go bad from the heat.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
I'm also a fan of Seafoam for this kinda thing. I use it in everything I own. It works well for seasonal stuff when it's "brought out" for the first start-up. It also does a good job as a maintainer I think. A few ounces in the tank every few tanks. It doesn't take much
Another vote for Seafoam here. Great product.
Gary
Ditto on the Sea Foam. It's good but personally I like this stuff better. I also do not run gas with ethanol in any of my small engines or in anything that sits for any length of time because the ethanol absorbs moisture from the air and it eats rubber. Your results may vary.
https://www.google.com/?gws_rd=ssl#q...jector+cleaner
Run Sea Foam in my Motorhome
Another Day To Be My Kid's Dad [emoji379]
When you can use Ethanol free gas as well.
http://www.pure-gas.org
Good question
This is a great question. I had never heard of Sea Foam until I read all the positive comments. I just ordered a gallon jug of it on Amazon.
Thanks for posting a very useful topic.
Pam
I agree the vacuum hoses are junk use silicone hoses
Throw another vote on the pile for Sea Foam, new plugs and wires (contact Ron...), and new vacuum lines...
I use Sea Foam in every thing no matter what gas I use.
Contrarian
Good old MMO, been using it for years and in the 2011 Spyder for almost five years. Sometimes, old is good.
I'm in....
Sea foam works for me. Don't have the standing gas problem but have to deal with the ethanol. ..
Savers
Pam
Pam,
You have saved about 15 cents per ounce of Sefoam ( which I have used for years). I do find the convience of a small can easier to handle than a gallon jug. Guess you could use a really small funnel to facilitate the transfer.
I didn't know Seafoam was sold in gallon jugs and am considering it.
Kaos
I used the small squeeze bottles from the dollar store. Come in packs of 3. I just put 5 oz of seafoam in it and take it with me to the gas station. Then I just throw it away when Im done.
Sent from my SAMSUNG-SM-G920A using Tapatalk
2007 M109R LE - To many MODS to list. Its cheaper that way!!!
Seafoam is used in boats, cars, and MC including .
Originally Posted by kaos
Pam,
You have saved about 15 cents per ounce of Sefoam <snip>
Kaos
128 x .15 = $19.20
Just sayin'
Pam
I thought with fuel injectors you did not have spark plugs! Guess I'm way behind.
I hve a bottle of Lucas oil I bought for my car. Is that good go use for the bike?
That would be diesel engines that lack spark plugs... and they pre-date you!
Sea Foam in the cars and pick up. Good stuff in that application.
I use Yamalube Fuel Med RX in each tank of fuel. Stops separation of the fuel and prevents corrosion.
If you ride a lot and go through fuel quickly it may not be needed, but as somewhat of weekend warriors, sometimes for different reasons the Spyder may not get run every weekend.
I have posted about the Fuel Med RX before, so a quick search should find more info.
Honestly, whether you run pump fuel or non ethanol, it is cheap insurance to add something. Cars are much less finicky than a motorcycle with FI.
