The fastest and cheapest solution is to cut the trailer 4 flat in half. Put the 2 halfs together to make a homemade square 4.
Or I would recommend going to a well stocked autoparts store or a trailer supply store then buy a matching square 4 and flat 4 and wire up an adapter. The wire colors will match on both plugs so easy to figure out.
What I did was buy a set of each pig tail (only way to buy them that I know of) and connect them. Easy pezzy. I used butt connectors, heat shrink tube each wire and then put in large heat shrink tube. Has worked well for 3 years. Took about a 1/2 an hour.
trailer
Try amazon and type in 4flat to 4square trailer adapters
Those square plugs can be bought .. Del City,Amazon and others. You will have to make up a adapter.. I had to do the same for the 622 trailer to my car flat.
http://www.delcity.net/store/4!Way-S...92.h_85143.t_1
Tags for this Thread
