Results 1 to 25 of 34
Thread: CQ CQ Hello CQ
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Default CQ CQ Hello CQ
    Well a lot has been written about using and setting up CB with Sena etc.
    Has any "HAM" setup an HT unit on their Spyder?
    Did you go 2M, 2m/440, 2m/70cm, something else?
    Did you go with a Icom, Yaesu, Kenwood, or opt for some of those interesting "cheapies"?
    Thanks for the input and thoughts
    AJ, N1BCK
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Jun 2015
    St Petersburg, Fl
    Cool
    Haven't been active for years, but all I need is more buttons and controls for my left hand to master
    73's
    WD4OAQ
    May 2015
    Oregon, USA
    k9bea here!
    I have a handheld Quansheng (cheap Chinese) 2m/70cm/FRS/GMRS/MURS radio.
    The radio was well under $100, and does most everything but CB bands.
    In my winter project pile, I've got a Comet CA-2x4SRNMO antenna antenna that I'll be mounting.
    The radio is connected to a Sena SR10, and then via bluetooth to my Cardio Packtalk headset.
    -Fratz
    Jan 2012
    Menlo, GA. 'Lookout Mountain'
    I have been waiting for a simple solution for ham radio on the Spyder. Most likely 2 meter. The GWRRA folks are big on the CBs. (Children's Band)
    I run HF in my truck while cruising around. Made a lot of contacts to Canada on the way back from the owner's event on Durango in 2014. I also have a 2 meter in there too.
    Nov 2015
    West Coast, Canada
    VA7JDG, not active for many years, keep posted if you find an easy radio mount for the ryde.
    Active Member Rocketman 2012's Avatar
    Oct 2015
    Carthage, Missouri 64836
    73's !!!!!!
    KF6GUW, Amateur Extra here.
    On a bike, I have carried a few HT's, in 2m-440 and 220 but just use the built in batteries and charge at night when traveling.
    In my Cage, I have been known to "Piggy-back" an HF (Alinco DX70-100watts-50 watts on 6M) and an ICOM 60 watt, 2M-440 on the bottom.
    My 2M-440 has a dedicated mag-mount for the pickup. UHF-VHF is the ticket in town especially in most areas with lots of repeaters. Simplex handles the rest.
    MY Alinco HF has a Diawa 6 position coax switch, running to 6 'Ham sticks,' in various bands, normally tuned to perfection in the center of the band or tuned to a dedicated frequency for the net I peruse. HF is much safer if you are out riding in rural areas as distance is no concern normally.
    On a bike I have always just pulled over to the side of the road to chat.
    Sam
    2021 Spyder RT ES6 PETROL metallic. Carthage, Missouri 64836
    Feb 2015
    Las Vegas
    Easy is not a problem
    I know WHAT I'm going to do, just a matter of WHICH HT.
    Think I'll be going with the Baofeng F9 with the Nagoya NA-771
    Going with Lamont's "Cuff", then adding RAM mounts to top.
    I already have installed a lighter socket in the left speaker panel.
    On the right of the holder, will strap a Sena SR10 paired as a second phone to my Sena 20S headset (second phone because already have SM10 streaming everything else
    Will plug HT and SR10 into socket.
    Would be nice if Bob finishes his work on using the built in PTT switch but don't think it's going to happen.
    So when traveling in a "group" will drop in the Midland CB for bike to bike and when Lone Wolfing it, drop in the HT.
    AJ
    Quote Originally Posted by SmoovOpRatoR View Post
    2014 RT-S
    2014 RT/S , Black
    Oct 2011
    south central Nebraska
    Quote Originally Posted by PaladinLV View Post
    AJ
    Please post a picture of your setup when finished
    maybe I could setup my Icom w32 somehow
    Henry N0HA
    May 2015
    Oregon, USA
    Here's a few pictures of my mount. It's a RAM mount that clamps on the left handlebar just inside of the controls.
    The SR10 is connected to the back of the RAM mount, and thanks to Doc, I've got a cable that connects the Can AM on-board entertainment system to the SR10. (AM/FM/iPod)
    The PTT is mounted on the left grip.
    -Fratz
    Nov 2015
    West Coast, Canada
    I have an old Yaesu hand held kicking around somewheres, I should dig it up and get back into the Ham world.
    Very Active Member WA5VHU's Avatar
    Cooper, TX
    My previous posts about my Amateur Radio efforts:
    http://www.spyderlovers.com/forums/s...431#post949431
    http://www.spyderlovers.com/forums/s...068#post893068
    Have fun on the air!
    Charles WA5VHU
    Current:
    2016 Honda CTX700 DCT ABS (faring model)
    Kip Moto SherpaX Cargo Trailer
    Wife Has:
    2014 Can-Am Spyder RT Limited
    2016 Lees-ure Lite Camping Trailer
    Previous:
    2013 Can-Am Spyder RS SE5, zoom-zoom!
    2011 Can-Am Spyder RT-S SE5, Foot Burner - Gasoline Boiling Stinker - Gas Tank Vacuum Puller
    Oct 2007
    Same here. ZL4JWJ
    Active Member ES44AC's Avatar
    Sep 2015
    Mocksville,NC
    I would love to put my DMR CS700 on mine at some point. We have a large MotoTrbo network here in NC. Getting a bluetooth adapter for the CS700 is high on my list this year.
    2021 RTL Marsala Dark Edition 4.13.2021
    Lamonster Riser
    Spyder Extras Docking station
    Zumo XT (my own Plug & Play cable)
    WrapMySpyder Carbon fiber partial kit.
    Baja Ron ultra performance sway bar and end links
    2015 RTS SM6 Intense Red
    born on date 3/2015 (mine on 9/12/15)
    Sold on 4.13.2021 33k of fun.
    May 2015
    Oregon, USA
    I mounted my antenna over the weekend, and now have a real one, instead of the rubber ducky. It's mounted on my 2015 RT-S in the pre-existing cut-out that is for the CB antenna. The only modifications were drilling a hole in the left speaker box assembly so I could run the cable under the seat and up to the radio. I also made the bend in the antenna, so the angle of it actually matches the angle of the FM antenna on the other side (and it doesn't stick straight out the back.
    I also installed my new license plate. In Oregon, we can have amateur radio call sign plates on motorcycles. Woohoo!
    -Fratz
    Jan 2012
    fratzba, did you pop out 'the plug' for the ham antenna or just mount in as it comes?
    Mar 2015
    Advance, NC
    Default Mountain top Repeaters
    We are blessed with mountain top repeaters and thus the low power cheep systems work well. Rubber ducky and all. A good number of Spyder ryders are Blue Tooth. I have found vhf/uhf wired to brain bucket works best. I may try the Sena coupling. ar de W4EH.
    Active Member SpyderCruiser's Avatar
    Nov 2014
    NJ
    Lightbulb
    Hi, KA2PFL and N2GUU here.
    This is the Ham radio on our 2015 RTL. The Radio is installed in the trunk (so I do not fiddle while Spydering down the road).
    The antenna is mounted here with a metal plate under it for strength.
    It was installed above the Chicken Band hole so it would line up with the AM/FM antenna like this. I took the photo at an angle, but side on both antennas are in line.
    The radio is connected to a Sena SR10 mounted here. I wired the PTT to the Spyders PTT switch on the handlebar.
    It works great, but kind of missing the 30 watts of a mobile dual bander.
    You can get to the PTT button, but you will have to cut the flex circuit and carefully solder to the plastic based flex circuit without melting it. If you want I can post a picture of the switch and flex circuit.
    2015 RTL , Red
    Feb 2015
    Las Vegas
    VERY NICE!
    AJ
    Quote Originally Posted by SpyderCruiser View Post
    2014 RT-S
    2014 RT/S , Black
    May 2015
    Oregon, USA
    Quote Originally Posted by Cavman View Post
    Yes, I just popped out the plug, and used a panel-mount NMO mount for the antenna base.
    -Fratz
    Mar 2015
    Advance, NC
    Default HF FEQ FOR CHAT?
    Maybe a 40 meter ssb freq for discussion? What ya'll think. Sorry to hijack but appears we have a few Hams here.
    Sep 2015
    Mocksville,NC
    I would imagine that HF would make the overly finicky electrical system on the Can Am Spyder have a meltdown. It is bad enough on a car or truck.
    Lamonster Riser
    Mar 2015
    Advance, NC
    Default reset hf...
    I sorry I ment to say HF freq for general chit chat, like here but faster. It does not have to be transmitted from your Spydee.
    Sep 2015
    Mocksville,NC
    Quote Originally Posted by Deer Slayer View Post
    No problem !
    I was not sure LOTS of people do HF mobile. A screw driver antenna on a motorcycle would be a head turner !!!!
    Lamonster Riser
    Mar 2015
    Advance, NC
    Quote Originally Posted by ES44AC View Post
    No problem !
    160 meter would be a whopper. I have mostly been an HF Ragchewer. It would be nice to get something started on ssb 75 or 40 meters ssb. Just have to wait and see. 73 ya'll... de W4EH ar...
    Active Member wd8ajj's Avatar
    Las Cruces NM
    I have added an APRS to my RT. Put the unit in the trunk. Bytonics all in 1 unit and got a stubby mini mag mount and Velcro it to the top of the plastic behind the seat. I built a little ledge to hold the GPS puck and unit. As far as radios go, I use a VX-7 and the ear mike from MFJ.
    Gary
    WD8AJJ
