it is a 2012 RS and he says the cap will only click when trying to take it off. I had seen on here a stant replacement # but all searching has produced nothing. General idea for getting the cap off is a lot of side pressure from anything that is big enough to grab hold of the sides, I think?????
I have had this happen, and I have pushed down on the cap, and also pulled up on the cap to get it to come off. Not saying that this will work, but it did for me. Either way, I would have a Stant cap ready to put on when they finally get the cap off.
Any help would be most welcome,
Advance Auto parts is 10835 & 11835 at Pep boys. The cap is smaller but seems to fit well enough. I've been using this cap 2 years now without any problems. Good luck getting the old one off.
First off I hope your friends gets the gas cap off. Question : Is there certain years of the Spyder that are effected or is it all gas caps that are on the Spyders. I had a 2012 and now a 2015 RTS and haven't had any problem removing the gas cap.
It's the gas cap that was, ironically, supplied as a recall in Jan 2013. The one before that had problems with gas vapors after a ride, particularly on a hot day. So your 2012 probably has the recall gas cap which is the one that then fails at some point. Mine failed at a petrol station and it took me 10 minutes to get the cap off, I put it back loosely but it still took another 20minutes to remove it when I got the replacement. Whether you have the pre or post recall one on your 2012 I'd recommend replacing it with the Stant.
I only used one click and so far no problem. Thank you to all who gave and shared their experiences how to remove the failed gas caps. This is a big help to anyone who may need.
Best way i think to get it off is use a propane torch. since it is plastic you will be able to expand it with the heat
as long as the bike does not blow up.
I had a 2012 RTS-SE5 A/C and had got a New gas cap( due to the recall) and now I have a 2014 RTS-SE6 no problems with the gas cap. Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
Propane torch for a gas cap, I want to be a long way away when you do this.
Instead of trying to burn off the residue why not use a solvent and a rag to remove the residue
Dean Secord AKA seaweed
Veteran: U.S. Air Force
2015 RT-S SE6
My Mods: TricLed Turn Signal, Squared Away Sept, 2016,SpyderPops Bump Skid, SpyderPops Missing Rock Guard, ION camera, Show Chrome Back Rest,
