Results 1 to 25 of 26
Thread: Coolant type
    Dec 2015
    Alvord,Texas
    Default Coolant type
    My apologies.im sure there is already a thread on this.i just can't seem to find it.
    Do I need to stick with the BRP coolant, or can I use a generic ethylene glycol coolant that specifies that its good for aluminum and all metals[IMG]uploadfromtaptalk1454864975106.jpg[IMG]
    2012 spyder rss
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
    Default COOLANT
    ...I am sticking with the BRP..( I have to use the new Orange stuff )..... ( with billybovine ) your anti-freeze is the more common type .......Also I think it lasts at least twice as long as they claim if not longer........Unless you leave it out in sub-freezing weather .....................jmho......Mike
    Jul 2011
    Mitchell, Ontario, Canada
    Yes. Since yours is a 2012. A good quality jug of the green stuff will work just fine.
    Bryant, Arkansas
    Be careful not to mix different color/types of anti freeze, it will coagulate and do a lot of damage. if you are replacing the coolant be sure to flush the radiator and all lines at least three times with clear water. if you are just adding some, use the BRP type that is in there now.
    Cruzr Joe
    Jul 2011
    If you do get the BRP stuff. Make sure you get the right kind as you can gather by the other posts BRP has 2 types. They cannot be mixed.
    Dec 2015
    Alvord,Texas
    Thanks for advice.I will stick with the BRP coolant,
    Does anyone know if Bajaron sells it?
    Bryant, Arkansas
    If you stick with the BRP brand, (and i recommend it) be sure that it is the same color as the coolant that is currently in your spyder.
    Cruzr Joe
    Oct 2013
    rome new york
    Quote Originally Posted by sulaco View Post
    With your 12 it is green
    Get prestones pre mixed you'll be fine. Made for aluminum
    Brp ridicoulous on prices.
    I use prestone in my 13. Just make sure of color
    Sep 2015
    Metairie, LA suburb New Orleans
    have always used this stuff with great results in all my bikes...the local speed shop that did all my work over the years only uses it.
    mail order is like $14 per half-gallon bottle.
    Jun 2014
    Schenevus NY
    Oh it's been so long since we've had a coolant color thread!
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    Oct 2013
    rome new york
    Lol
    Just look. If u can't see put hose down in reservoir put finger over the put in white or clear container.
    Brp does not have the market on antifreeze
    Dec 2015
    Alvord,Texas
    Yes, its green.
    Jun 2011
    Near Lexington, NC
    What aftermarket make can be added to the 1330 orange/red stuff? I'm not sure that just any "orange/red" will do and don't want to get into situation where I have to have it all drained and flushed.
    I just want a little to top off.............
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Oct 2013
    rome new york
    Yes, its green.
    As long as It's compatible for aluminum can use whatever.
    Don't beleive all the crap or use brp.
    Money making scheme.
    Antifreeze and oil have been around longer than BRP
    Default ORANGE/RED ANTI-FREEZE
    ................I haven't heard of any alternative to this type yet.......It would be expensive for a full change ( not with flush ) but I believe it lasts 3 times as long as they claim...sooooooooooooo.......Mike
    Jun 2011
    Near Lexington, NC
    Thanks Mike. Maybe I can squeeze a small bottle full off the
    techs next time I go in for service!
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    SoFlo
    To top it off with a small amount, just add distilled water.
    I have plans to drain and flush ours from the 14 RTs.
    Plan to use USA made Peak brand and this is the stuff with distilled water.
    http://images.peakauto.com/PEAK_long..._no%20back.pdf
    PK
    SoFlo
    Wanted to add, the color of the Peak anti freeze I mentioned is Flourescent Yellow. Not pink nor green and if a leak does occur should be visible with a black light.
    PK
    Default ANTI-FREEZE
    PK
    ......Paul, what is the amount in our RT's ? ? ?......Mike
    May 2018
    Bristol
    Just had system flushed and replaced, ok too add peak orange, 50/50,? cant tell color in tank. How an you see level thru milky plastic. Tks
    Apr 2020
    tucson az
    I don't change my antifreeeze until I know it won't work like it should. I use an antifreeze tester to check it 2-3 times a year. they cost about $4 on amazon or the same a walmart
    https://www.amazon.com/Prestone-AF-1...24898553&psc=1
    2011 rt , pearl white
    Mar 2008
    Hesston, PA
    Does your antifreeze tester check the ph??? That is just as important as the freeze/boiling points of any coolant especially in the all aluminum environment...
    INDIANA, USA
    Default Coolant PH Value
    Quote Originally Posted by larryd View Post
    Definitely need to carefully check the 'PH VALUE' of your Spyder Coolant once a year. .....
    ENJOY YOUR LIFE WITH A SPYDER
    Aug 2013
    Quote Originally Posted by Little Blue View Post
    Oh no
    Was looking to flush mine and it’s been 9 years.
    Can’t seem to find the capacity on a STS though.
    Mar 2011
    Pence, wi.
    I thought I read that you can use Dex-cool in the newer bikes. If anyone knows for sure, let us know. Thanx!!
    2022 Spyder RTL- Chrome , Larger brake pedal Deep Marsala Red
