Results 1 to 5 of 5
    Active Member rmag's Avatar
    Jun 2015
    miamisburg, ohio
    Default Windshield Support Removal
    I need a little advise. I have a 14 RT Limited and would like to have the windshield support powder coated. I have all the screws removed, what is the trick with the center arm? I tried the advanced search and didn't see anything.
    Thanks, Rich
    2014 RT Limted, platinum, with matching 622 trailer.
    Ultimate tall boy seat w/adjustable back rest, Corbin armrests, Spyderpops bumpskid & missing belt guard, BRP side air vents, Lamonster lidlox, cargo nets, Stebel air horn, Wrap my spyder accents......and more
    Default WINDSHIELD ARM
    ......I have removed the ARM and it is not an easy procedure....a lot can go wrong and it could get expensive if it does ....so why do feel it needs to be POWDER COATED ......it is not a part that is subjected to excessive WEAR....You can get it out and leave it on the shaft and just PAINT it......this is what I would do.............Mike
    Jun 2015
    miamisburg, ohio
    Default Not the arm
    I maybe did not make my self clear, I'm trying to remove the support from the center arm. Do I need to chase the sleeve out of the arm to free the support?
    Sep 2015
    Metairie, LA suburb New Orleans
    Jun 2015
    miamisburg, ohio
    Default Got it!
    Thanks for the help.
