LED Signals
I added LED light strips to the top of my mirrors. Work great, but now the signals blink very fast. I've seen posts of others who have done this and this problem was never mentioned. Anyone know what I might have done wrong?
Year?
Sent from my VS990 using Tapatalk
14 RT-S , Stock Large brake pedal White Pearl
See hyper flash reset on Spyder RT on you tube
NEW/CURRENT (Wife's Bike, I ride Goldwing/Africa Twin)
2023 RT Limited Petrol Blue Metallic
Working on the upgrades... so far... Show Chrome Isolator Fuse Block, Tackform Adventure Wireless charger phone mount
OLD/TRADED
2015 RT Limited Intense Red Pearl
Farkles: Ultimate Tallboy seat, FOBO, JT Dash Mount, Lamonster Spyder Cuff, Kradellock, TricLED lighting - fenders, A-Arms, saddlebags, run/brake, Custom Dynamics high brake light, brake modulator, Drink2Go passenger, MUTH turn signal mirrors, Bajaron sway bar, Kuryakyn ISO grips, SpyderTV front grilles & rear trunk organizer, homemade trunk light
Pending: Elka shocks, Yokohama S Drive rear tire, EVO 595 front tires, Centramatic balancers, Neutrino black box
Lamont of Lamonster Garage states this works on 2014-15 RT's.
don't know about any others
These blinkers are a no-brainer
Why blinkers aren't built into mirrors and available as stock is beyond me. A "must have" in my humble opinion. What was Lamont showing, just an LED light strip?
it has to do with LED drawing at a different rate than regular bulbs. Had this issue on my yamaha, You just need a little blinker relay, or switch them all to LED.
Hyper flash LED
Hey guys, you will find many discussions and "fixes" for the hyper flash problem. The issue, as stated, is that Nanny is "looking" for a certain current draw for the signals. To her, too much indicates a short...too little indicates a bulb out. Either causes hyper flash to warn you that something is wrong. The LED bulbs draw considerably less than the OEM halogen bulbs, sooooo...hyper flash! The suppliers will have you add resistance (several recipes available) to mimic OEM draw, and/or circuits that will make your signals flash ALTERNATELY to the rear turn signals to lower the current draw on the system at any one moment. For me: 1) I HATE alternating signals- I think it is confusing to other drivers! 2) One main reason for adding LED's was to reduce current draw so it can be used for other things...like.. a SOUND SYSTEM So it would be counter productive to add a bunch of resistance. If you agree with any of this, do yourself a favor as follows... Amazon has TINY cheap WATERPROOF RELAYS that will take your new LED signals completely out of the monitored system. They fit neatly behind the gauge cluster and react to your turn signals with literally no delay! BOOM! Less current draw, and NO HYPER FLASH!
...just sayin
Dan Am
(PM me if you want more info)
Send a pm to Blueknight911( Mike) he can help you. Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
THANKS GUYS!!!
I asked the same question at the local Can Am dealer and he said I needed a resister on each LED strip I added. You would think the service guy would know how to reset the system after adding the LED's .. Thanks again. Don....
After adding LED's to our Mirrors, front fenders and then adding a Big Bike Parts 3 Break light with turn signals, we got the "Hyper-Flash" issue. Just happend upon this thread and tried Lamont's trick and Viola........no more HYPER flash! Thanks to EVERYONE!
Ride Safe All
2014 RT Limited (Charlotte) in Cognac, Kuryakyn Grips,Tri-Axis Handle Bars, Rivco Armrests, a "finless" BT Dongle, TricLed Fender, Saddlebag, 3rd & 4th brake Lights, Custom Dynamics "Magic Strobes Brake Flasher", BajaRon Sway Bar & Spring Adjusters, Lighted Bumpskid, Rivco Highway Pegs, Rivco Cup Holders and Baker Built Air Wings. 215/60R-15 General Altimax Rt rear tire. 155/60R15 Kumho Solus front tires.
