Results 1 to 16 of 16
    Jul 2013
    Piedmont, SD (Black Hills)
    Default Enclosed trailer questions
    For those that have put Spyders in enclosed trailers, what size will fit 2? Will a 7x14 cut it? Is there a need to strap them down inside? Or just use wheel chocks that are mounted solid?
    Apr 2013
    Browning, Illinois
    I have a 7 X 16. With other things we carry I think 2 would be a stretch in it.
    Default WHEEL CHOCKS
    For two Spyders six would work......However hitting a bad bump would probably end up doing damage. As far as tying them down, I only use one heavy duty rachet strap placed over the rear tire ( in-line ) and two side blocks on the front tires. I have had two fairly serious vehicle incidents and the Spyder never moved.......cost of one Strap about $ 5.00......Mike
    Dec 2010
    Fountain Inn,SC
    I have a 7X12X7 the height is so you don't have to duck on it when you climb off the . That being said I wish I had brought a 14 or 16' long just for the extra room. I strap mine down like brp recommends hadn't had a problem when hauling it. I thought I would be hauling it more but it is just too fun to ride. So when I not riding the sits in it.
    Active Member thereverend's Avatar
    West Monroe, LA
    Default Here
    Quote Originally Posted by jwulf74 View Post
    Is what I use with my 7x12
    The Spyder will fit in anything 6 x 10 and over. It just depends on how much room you want for other stuff and to get off and on the Spyder. Others have given you good info on tying it down.
    Apr 2015
    Brockville ONT
    I have a 7x10 and use e track on floor to put strap over front tires.Works great.It,s a V nose so room in front for my tool box screwed to floor and hang my gear.
    Bill
    2018 RT Anniversary , Brake pedal extended
    If you want to tow 2 Spyders, you've got some figuring to do...
    If you want them "nose to tail" figure on about a 7x20 trailer.
    If you want to drive one on, and then back the other one in, you'll want some extra width for the offset, but the length of the rig can be shortened up by a bit...
    8x16 maybe?
    It really helps to take the bikes along for a test-fit.
    Good luck, and Happy Hunting!
    Apr 2013
    Monument, Colorado
    RTS & STS will fit in a 8.5'x14' box. Both backed in starting with the RTS. The STS backed in, the back tire to about the foot boards of the RTS. I believe a 8'x14' would also work
    Quote Originally Posted by WasWinger View Post
    Oops, missed the part about 2.
    May 2013
    Indiana
    Quote Originally Posted by fispyder View Post
    I I thought I would be hauling it more but it is just too fun to ride..
    This is THE reason I can't justify spending what an enclosed trailer costs.
    2021 Marsala Red Metallic RT Limited
    Jul 2013
    8ish X 14 sounds like about the smallest. Yikes. Thanks for all the advice everyone!
    Eastern North Carolina
    I use a 7x20 Vee Nose. When I got it we had two RTs that fit very well. My good friend Wiredux just bought a 7X20 Vee Nose as well. I have D rings in the floor that I use to tie down the Spyders. They need to be secured. Some folks have the track system. I would not recommend anything smaller then a 20 foot.
    Apr 2015
    Brockville ONT
    Your not the only one that missed the part about 2 I would check with a dealer as I,m sure they ship spyders
    Bill
    Sep 2008
    TX
    We use a 7x16 w/a 3' v-nose. Back the F3 in first and drive the ST in. Chocks are home made and hold the rear wheel only. Two blocks, one on the outside of each front wheel keep the front end from moving side to side. See image:
    This photo was taken while in the fit up stage with the ST in first but the general space is the same.
    Wayne
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    Jul 2013
    I haven't been on in a while. Thanks for the pic. That helps a ton!
