Results 1 to 20 of 20
    Oct 2015
    Elk Grove, CA
    Default Bike mounted Garage door opener
    Is there a bike mounted Garage door opener available for the Spyder RT. The one that I had installed on my Harley was connected to the high/low beam headlight switch. Changing tge position of the switch would initiate the garage door opener to raise or lower the door.
    I look forward to your responses.
    Jun 2015
    AZ
    I velcroed mine to under the dash, just behind the pull down safety card. Works great just tap the button and go. Do not even notice it there.
    I Velcroed mine to rear inside surface of glove box.
    What's the matter?
    Didn't you believe us yesterday???
    http://www.spyderlovers.com/forums/s...ge-door-opener
    Mine is still where I left it; mounted in a cut-out, in the glove box's foam liner...
    Oct 2011
    Kalamazoo, Mi
    try this one; if you've got dip switches this should work.
    http://www.amazon.com/Transmitter-Solutions-390LMD21K-Keychain-LiftMaster/dp/B002P5TS6K
    2018 F3-T
    2018 F3-T , Pearl White
    ThreeWheels came up with a very innovative design...
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by Sonny P View Post
    BRP is still trying to catch up with Harley technology! 😂
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Default Interesting..!!
    Key remote, wired to a switch on the dashand your set....
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    I purchased a keychain size remote and velcroed it to the inside wall of my glove box. I just open the lid and press the button as I'm approaching my house. I don't even have to remove the device from the velcro. Much cheaper than the ones you install on the bike. I still have plenty of room in the glove box for odds and ends.
    Pam
    The only problem that I see with having to open up the glovebox:
    Make dang sure that you don't have to turn your bars!
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    Of course I do close the lid prior to turning into my driveway, but ..............
    FYI, turning the handlebars closes the glovebox lid
    Pam
    Sep 2015
    Dallas
    I did what Pam did. Works great and is not expensive.
    Quote Originally Posted by Pampurrs View Post
    Pam
    Not if your hand is still in there!
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    The remote transmits and activates the opener from a great distance. By the time I turn into the driveway, the door is halfway open. Not much chance of my hand still being in there.
    Pam
    You are FAR better at doing several things at once, than I am...
    Sep 2014
    USA
    Pam
    Velcro mine to the glove box wall in the front works well..I am usually driving straight when pressing the button to open the garage door and never had a problem..
    For the record; here's a pic of how I mounted mine.
    Mar 2012
    Florida Space Coast
    Quote Originally Posted by kbwitt View Post
    That's the same I did with mine.
    Jan 2015
    southern WI
    X2!
    2016 RTS , Pearl White
