Results 1 to 5 of 5
Thread: STS cruise
    Aug 2015
    New Mexico
    Default STS cruise
    there was a thread on how to mod the switch housing but I cant find it so I will tell everyone what I did to get the cruise working on my wifes 2013 sts . I replaced the right hand switch housing with a RT housing and it works Awesome. the can am uses electronics' for cruise and NOT Cables so the computer thinks its supposed to be there. again I did not mod the switch I just replaced it. it only requires you to remove the right switch housing, remove the plastic bottom cover from the handle bar and right side upper panel, mirror, and the upper panel at the frunk unplug the throttle wire and replace it with the new one .. took me 30 minuets start to finish
    Default CRUISE CONTROL
    Quote Originally Posted by james199 View Post
    ..............I WONDER IF THIS WOULD BE A LESS EXPENSIVE OPTION FOR THE F-3 SWAP ?????.....MIKE
    Feb 2014
    Roswell NM
    For the ST at least, you can take the right hand switch apart, remove the "dummy" switch and replace with the working switch from the new donor assembly. The black piece in my hand is all that needs to be changed. The white rectangle above my hand is the actual Cruise Control electronic switch. It was already on my non cruise ST.
    So...the cruise is already on your ST. The dummy switch merely prevents you from using the cruise.
    Here is the link to the thread:
    http://www.spyderlovers.com/forums/s...=cruise+switch
    Aug 2015
    New Mexico
    Quote Originally Posted by Craniac View Post
    THATS IT !!!!!!! THANK YOU .. I looked but I just couldn't find it .. I'm a analog man in a digital world ..lol.. now that I got a spar I'll tear into the stock one and mod it
    Aug 2015
    New Mexico
    I picked up a new switch assembly for under 200 dollars so it was a no brainer and the wife is Super Happy and we all how that is
