Page 2 of 2 FirstFirst 12
Results 26 to 41 of 41
  1. #26
    She'd rather ride; than read...
  2. #27
    Jun 2013
    queens ny
    it has happened tome a few times, but don't remember how many
  3. #28
    Danbury Connecticut
    Thank your lucky stars for your good fortune.
    I always have to push the mode button for a cold start-up.
    Of course, like everyone, at short gas stops, I can start without hitting the mode button and the boot-up continues while I'm drving away.
    Why can't we have that as the normal mode of operation.
    IBA #47122
    2020 RT Limited Asphalt Grey
  4. #29
    Active Member spyderyderjim's Avatar
    Feb 2012
    Tucson, Arizona
    Default 2014 RT check left fusebox R1; R2 (pre-start relay) & R3 relays are pushed in tight
    Have any of you had this happen yet?
    In the past six weeks; I've encountered 10 separate times, that I didn't have to push the Mode button for a cold start-up...
    The bike had sat overnight, and it would just go directly to the LED Speedometer read-out; rather than forcing me to endure the full start-up protocols.
    What gives?
    If the bike is continuing to boot-up systems as I run it, I sure haven't noticed anything not functioning in a normal fashion...
    Hi Bob,
    Check in Left Fusebox the R1 & R2 Relays are pushed in real tight, (push in hard all relays & fuses).
    R1 Relay is Reverse actuator
    R2 Relay is Pre-starting
    On my 2014 RT-S SE6 I had to replace B.O. R2 relay (I replaced R1 relay also); (probably caused by ryding on a really rough, bumpy mountain road at high speed).
    I found several relays, fuses a little loose in both Right & Left fuse boxes (Oct 2014); check LFB F7 & F8 fuses are not blown.
    Jim
  5. #30
    Thanks!
    Our roads around here can be pretty rough, so it sure could have loosened-up some of the relays...
  6. #31
    Apr 2014
    Rougemont, NC
    Post
    Safety Card?...what's that....
    2014 RTS-SE6 , "Harvest Gold" Cognac
  7. #32
    It's put there for the safety of others...
  8. #33
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Safety Card
    I enlarged, printed, and laminated the above. Thanks Bob. Now installed on the It is the proper use for the safety card pullout.
    Unautherised touching of my Will cause:::::
    Kaos
    2014 RTS , Circuit Yellow
  9. #34
    That's why I posted it: so that folks could help to end the...
    ..."Chaos"!
  10. #35
    Jun 2014
    Gettysburg, PA
    Default I've had something even MORE odd happen....
    So, the past two months, mine started doing the "no mode button" before starting. SOMETIMES...... I get no mode button required....then the Spyder starts.....THEN the "Press Mode Button" screen comes up AFTER it's already running and moving! SO, I have to press the "mode" button to see the speedo screen! I ride LOTS of bumpy roads. After reading this thread I'll check the relays and fuses. Thanks all!
    NEVER, look straight up at a bird ....NEVER drink downstream from the herd ....and NEVER, EVER squat....with your spurs on!!!
  11. #36
    Active Member trikerbiker645's Avatar
    Apr 2016
    wi
    Default start up
    I just hit the eco mode switch as soon as I get on and hit the start button, fires right up. Don't have to wait for dash to come on/boot up. Read somewhere that it was possible to do this as the Canadian bikes can.My buddy also starts his the same . Both 2015 RTS bikes. safe riding
    Baja Ron sway bar, Spyder Dock, Highway Brackets,Trident pegs, Spyder Decals, Signal Mirror led strips, Utopia backrest, 5 pc. Hopnel liner set, cargo nets side/rear doors. Mesh bag front trunk, foam grips, spare trunk key, passenger armrests/storage pouch's, ram mounts/GPS, Drink holder,Phone, Passenger clamp-on drink holder, rear trunk tap light, custom plate frame, spyder fastener bolts, adjustable lower mirror wind deflectors, F4 Customs windshield -wide,tall,clear,vent,Chrome Spyder grill.
  12. #37
    NorCal - Northbay
    What gives?
    SkyNet calling....
  13. #38
    Invalid Emails
    Oct 2015
    Deland, FL
    Have had this only on hot start within 30 minutes of shutdown. If there was a way to permanently remove it I'd do it in a heartbeat.
  14. #39
    Jan 2016
    PA
    Your Spyder is saying that it might begin to start trusting you.
    This trust is a fragile thing and can be shattered with a a few tenths of a pound out in tire pressure, oil belatedly checked at 305 miles or
    maybe the brakes not properly inspected.
    Your Spyder is fickle.
    It starts to trust you then you do some bone headed human thing and you are sent back, as a naughty school boy or girl, to reading the safety card.
  15. #40
    Quote Originally Posted by spyderCodes View Post
    This makes perfect sense!!!
  16. #41
    Sep 2009
    La Valle, WI
    My 15 RT-S has done it. But mine does not need to wait for instruction screen to start. I turn key on when the display says can-am I push to mode button and it starts.
    2018 F3 Limited , Oxford Blue
