Yep, $400 and the bulb is held in with a glorified paperclip that is VERY difficult to use.
1 2 many
![Quote](images/misc/quote_icon.png) Originally Posted by jcthorne
i think there is 1 too many "0" in the dollar figure.... these are cheaply made, and i've since seen better on AMAZON for under $100.....
BRP, shame on you....
Dan P
SPYD3R F3-S
![Quote](images/misc/quote_icon.png) Originally Posted by SPYD3R
Dan P
SPYD3R F3-S
Is the Amazon light something that would fit well in the factory hole?
YES
![Quote](images/misc/quote_icon.png) Originally Posted by TommyBwell
TOM;
SOMEWHERE ON THIS WEBSITE, IS A POST THAT TALKS ABOUT THOSE LITES.... AND IF I REMEMBER CORRECTLY, THEY WERE EITHER $89 OR $99 FOR A PAIR....
DO SOME SEARCHING ON BOTH SPYD3RLOVERS AND AMAZON, AND I'M SURE YOU'LL FIND IT... I WILL ALSO LOOK, AND IF I FIND IT, I WILL AGAIN POST ON THIS LINK....
HELP FOLKS, ANYONE KNOW WHERE THAT POST IS....????
DAN P
SPYD3R F3-S
TOM;
DAN P
SPYD3R F3-S
The housing is indeed a standard Hella fog lamp. The Spyder specific mounting brackets, harness and lighted switch are not included with the Hella lamps. Still they are WAY overpriced for what they are.
$80 DIY Aux Lights
THX
![Quote](images/misc/quote_icon.png) Originally Posted by zuni
THANX FOR THE HELP.....
ALWAYS APPRECIATED....
DAN P
SPYD3R F3-S
Installing the light bulbs themselves on the F3 Aux lights was the least of my problems. Installing the complete Aux unit was a major pain getting the units to lock into place. The light bulbs went in pretty easy for me. I changed the standard H3 bulb that came with the set to a H3 LED bulb option so that the light would be white instead of yellow. The yellow lights just did not look right next to my LED Headlight mod from XenonDepot
I THINK
![Quote](images/misc/quote_icon.png) Originally Posted by Tazzel
TAZZ.....
I'M THINKING YOU CHANGED THE H-3 BULBS WHILE THE HOUSING UNIT WAS OUT OF THE BIKE.... OTHERWISE, YOU KNUCKLES WOULD BE CUT & SCRATCHED LIKE MINE....
DAN P
SPYD3R F3-S
Didn't the modified socket work for you?
Just another crappy day in Paradise....Aloha!
![Quote](images/misc/quote_icon.png) Originally Posted by HIspyder
Modified socket? I just had the 3 prong elongated screws that had to be locked in place.
http://www.spyderlovers.com/forums/s...ctions-missing
Skip down to #7
[QUOTE=SPYD3R;1053520]TAZZ.....
DAN P
SPYD3R F3-S[/QUOT
One bulb I replaced before install and then one I did after the install, just so I could tell the difference between the standard H3 and the H3 LED in color and brightness. The little latch was easy for me to get to but then I had the advantage of knowing how it worked because I had the whole unit out so I could get a close inspection of how everything operated.
Oh yeah I did make one of those but it started tearing the plastic tabs on the AUX unit. I used a variety of other tools and some curse words and once I greased where the tabs turn into place, it locked.
I have the aux lights and like them. They were difficult to install but what I did was pop off the white caps on the bolts. Then install the frame. It is much easier to lock the keyed turn buckles without the light attached. Then put the light back in and tap the covers onto the opposite piece. The covers lock the lights to the frame. I replaced the bulbs a couple of days ago...no big deal. Remove the side panels, remove rubber boots, lift up metal latch, pull out old bulb and replace. It is a keyed fit, so just wiggle the bulb a little to get it done. The lights wire assembly is professionally OEM quality with the included switch. I agree they are over priced but I got mine on eBay for much less. Central Powersports in Orlando was the seller. You'll never buy another light that will fit and connect effortlessly to the bikes electric system without a lot of effort. By the way, the lights work and look great. My 2 cents...
Yes, they were the OEM Can Am Aux Lights. I think your issue misleads others thinking of buying the lights. I would definitely buy them again. Yes, they were difficult to install but not as difficult as replacing your main headlights. Have you tried that yet? When anything says less than an hour to install, I plan on three. The key is patience and the right tools. Trying shortcuts or incorrect tools makes any installation difficult.
I’m no expert but the F3 BRP AUX light unit seems good quality to me. Very solid which accounts for the hard install. Absolutely no flex in any of the materials. Overpriced but what BRP accessory isn’t? I found changing the light bulb pretty easy. Understanding how the clip holds the bulb in and unlatching it is hard to see in such a tight space but once learned its pretty easy.
