Page 1 of 4 1234 LastLast
Results 1 to 25 of 78
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    Default 1330 oil change interval
    The maintenance schedule in the owners manual states that the oil should be changed every 9,300 miles. Since I changed my oil at 5,000, my assumption is that my next oil change should be at 14,300 miles on the odometer, rather than 9,300. Is this assumption correct? I just want to make sure because I am now approaching 9,200 miles on my .
    Thanks!
    Pam
    Mar 2013
    Maumelle, AR
    Default That depends...
    Quote Originally Posted by Pampurrs View Post
    Thanks!
    Pam
    on the oil you use. What's the best oil to use and why?
    2020 RT Limited , Chalk
    Sep 2014
    3rd ROCK FROM THE SUN !
    If you follow BRP's recommendation on 9300 oil chance intervals ... IMHO your assumption is correct..
    osm
    Jun 2010
    Las Vegas
    That's how I do it.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Here's what you do..!!
    Add the 9,300 miles to your last mileage a oil change...like you did.. mho I would not wait that long...seeing a lot of testing and oils start fading long before that...
    Very Active Member MRH's Avatar
    Apr 2012
    Los Angeles and Santa Ynez, CA
    Lou at Pirate Powersports, who does my work and whom I trust, thinks that 5000 in climates like California, which can get very hot, is a better interval, and I tend to err on the side of caution and see him every 5000 for oil and any tires or brakes that need changing.
    2020 RT Limited in the ultra cool Deep Marsala Dark edition.
    Baja Ron Anti-Sway Bar, LED reflectors, Lamonster USB Charger (and phone mount), Can-Am Low Windshield, X-Creen Tour Variable Windscreen Spoiler Blade, Power Commander, Dilithium powered Flux Capacitor (not yet fully functional).
    Maintained by Lou at Pirate Powersports.
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by MRH View Post
    I've changed the oil every 5,000 on all my previous bikes. This is the first one I've ever had that recommends such long intervals. I'll probably change it sooner than what they say just to be on the safe side.
    Pam
    Apr 2014
    Beloit Kansas
    I like your 5k plan. Bur isn't it nice to know it's not going to grenade because you went a couple miles further.
    Bryant, Arkansas
    You are correct.
    Cruzr joe
    Every 9,300 miles...
    ...OR ONE YEAR!!
    Whichever shows up first!!!
    RE: 1330 oil changes. That first is recommended at around 3000. Every 9,300 miles thereafter, OR once a year--whichever comes first.
    Mine was changed out at 4,500 for the first--due to a lot of miles quick, and having to wait a week to schedule the break in change. I had 9,300 miles on at seasons end. Oil was changed at the beginning of 2015 at 9,300. Oil was recently changed at 19,500 and I am considering oil changes to be done for this year. I am thinking about 28,000 for my next oil change.
    No issues with my unit. The 1330 has not burned any oil. Consider me a 9,000 mile oil change field tester for now.
    Dec 2008
    Jacumba, CA
    I will change between 9300 and 10,000 miles. The oil doesn't know that and neither does the engine.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    Since one is concerned about protecting a big buck (at least for me) investment the simplest and perhaps most economical way to keep an eye on things is periodic oil analysis. The real bottom line is BRP would be a gang of absolute ignorant bufoons, which they aren't, to establish an oil change interval that they weren't extremely confident would lubricate and protect the engine for 9,300 miles if the proper grade and API service code oil is used.
    Thank you...
    Vermont
    Default Oil Change on the 1330 engine
    Last year(10/2/14) I had the oil/ oil filter changed @ the 3,000 mile break- in time frame, this riding season I have over 10,000 miles, and (Thursday the spyder goes in for it winter hibernation), some time this year or next year the oil will get changed, @ the dealership.
    Someone give me a suggestion.......... I have 10,000 miles on spyder, + 9,300= 19,300. Would 19,300 miles would be my next oil change?????
    I have a 2014RTS-SE6 ( 1330 engine)
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Active Member Blade's Avatar
    May 2015
    Chesapeake, VA
    Post Next Oil Change
    My understanding after reading the Manual is that a oil change should be accomplished at 9300 miles but if the clock starts after 3000 mile check up than the oil change interval is 6300 miles ( 3000 + 6300) = 9300. Unless I misunderstood what I read.
    Blade
    May 2013
    Indiana
    Default More Dealer BS???????
    I just had my first/end of season service @2400 miles. My dealer told me that my second service should be when the odometer reaches 9300 miles, or in one year. By their math my second oil and filter change could be @a 6900 mile interval.
    Like many here, I've switched to a wet clutch compatible commercially available 10W-40 motorcycle oil. I also will error on the side of caution and change the oil @4-5,000 miles.
    2021 Marsala Red Metallic RT Limited
    Based on pages 120-121 of my user's guide I interpret the change intervals as the following: first one, 3,000 miles and every one after that initial change at 9,300 incremental miles or once/year. If one doesn't put 9,300 on the Spyder within one year from the 3,000 mile change, change it at the one year point. If you are putting lots of miles, first change is at 3,000 odometer miles and second is at 12,300. IMO, any dealership telling you any different is pegging the BS meter and wants some of the contents of your wallet. If I had more than 4,650 on the currnet fill of oil and was going to lay the Spyder up for the winter, which I thankfully don't have to do, I would change it befor laying it up as I would want to store it with fresh oil. YMMV.
    But isn't this VERY simple schedule being over-thought, and beaten to death?
    Pragmatic Member
    Mar 2015
    San Tan Valley, AZ
    Based on pages 120-121 of my user's guide I interpret the change intervals as the following: first one, 3,000 miles and every one after that initial change at 9,300 incremental miles or once/year. If one doesn't put 9,300 on the Spyder within one year from the 3,000 mile change, change it at the one year point. If you are putting lots of miles, first change is at 3,000 odometer miles and second is at 12,300. .....
    That makes sense...
    I've put 9,200 miles on my Spyder in its first 4 months. I think by the time I get to one year I'll be on my third oil change
    Pam
    Deanna
    19,000 give or take a few. I don't think you have to worry about it being on the exact mile for the oil change. How far we stretch it...that could be up for discussion. Never a problem doing it early IMO.
    Vermont
    So should I have the oil changed @ or around the 10,000 mile mark?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Deanna
    Based on what you posted earlier. You did your break-in change at 3,000. Then 9,300 later would be at 12,300. If you are now at 10,000 you could wait until spring. Some will suggest putting new oil in now for the big winter sleep. If you do it now--(10,000) then your next oil change could be around 19,300. If you wait until 12,300--then your next would be around 21,600.
    All these numbers are give or take. I am going to use maximum 9,000 in between oil changes for now. Maybe earlier--but not much later.
    Nov 2013
    Oro Valley Arizona
    Deanna
    YES
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Active Member robtdonna's Avatar
    Ellijay, Georgia, United States
    I don't worry about mileage. One year is my interval. (Yes, when and if I sell someone will be getting a very low mileage machine !)
    Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl.
    BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
    Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
