Results 1 to 18 of 18
Thread: Front Foiler ?
    Apr 2015
    Boulder City NV
    Default Front Foiler ?
    Is there any product out there that can protect the lower front end foiler ?
    N. Va
    Make sure your springs are strong enough to set sag correctly + have sufficient top end capacity to keep you from bottoming out easily.
    You didn't indicate if you ride 2 up alot / what weight do you normally have on the front end?
    Then there is the possibility you may be going up a relative steep driveway where the initial approach is enough to cause you to scrape the nose?
    Jerry
    Bryant, Arkansas
    Spyderpops makes a BunpSkid that protects the front end. Call him at 501 627-4008, or visit his website on the home page or go to www.spyderpops.com
    cruzr Joe
    Default Spoiler...
    it's called a bumpskid because it is a bumper and askid plate. The oem skid just covers the frunk bottom and is lightweight. Spyderpops bumpskid is heavy duty and covers a larger area. Now offered with lights...
    Dec 2014
    Lee's Summit, MO
    Default Worth the money
    cruzr Joe
    The bumpskid is well worth the money and it is easy to install. This was one of the first accessories (farkles) I put on my RTL. It has been tested several times without failure.
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Default An Ulternative
    Then there's this Wear Bar Accent piece from Value Accessories that costs a lot less. I have one, and I really like the looks of it.
    I agree with Jerry's comment above. If your front end is routinely bottoming out, that can be fixed by upgrading the shocks, or adding BajaRon's shock adjusters to your existing shocks. BajaRon's shock adjusters are really a great value, and they get the job done well.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Throw another Bumpskid vote on the pile!
    GOS member (Girls On Spyders) Spyder Smyles's Avatar
    Dec 2012
    Aberdeen, MD
    Bumpskid all the way.....First thing I added to my 2013 RT-S. It was also one of the first things I added to my 2015 RT-S and my husbands 2015 RT-L. Like the looks and great protection.
    CURRENT: 2015 Yellow RT-S SE6 "Smiling All the Way"
    CB, Satelite Radio, BRP Vented Windshield, BRP Adjustable Handwings, Cup Holder, EZ Pass Holder, Side Saddle Cargo Nets, Smiley Face FLO, Smiley Flower Face Decals, Tri Axel Handlebar's, Corbin Heated Seat, Baker Built Upper/Lower Air Wings, BumpSkid, High Third Brake/Running Light, Brake/Running Light/Turn Signal License Plate, Turn Signals in Mirrors.
    PAST: 2013 Yellow RT-S SE5 - Loaded with lots of goodies.
    Another vote for the bump skid. Although I'm very careful about parking lot speed bumps and also have to leave/enter my driveway on an angle because of the grade I was surprised ar the marks on the underside of the skid plate the last time I had the front end off the ground.
    The Spyder has a decent ground clearance on the front end when not loaded. But gearing up and riding 2-up on an RT can reduce ground clearance in the front by 2" or more. Add to this hitting the brakes as you traverse a speed bump or enter a driveway and you'll lose even more precious ground clearance. Without being able to adjust the shock spring pre-load to compensate for the additional weight, you're going to be hitting the ground more than you'd like and harder than you should.
    It is interesting that every Spyder made through the 2012 model year came from the factory with shock spring adjustment capabilities.
    There are, of course, various remedies. That's what 'Aftermarket' is all about.
    Eastern North Carolina
    Bumpskid. A farkle for your 'foiler'.
    N. Va
    So lets review. If you are scrapping the bottom now, then add a bump skid which adds additional thickness to the bottom... it is going to scrape more often... Why would this be a surprise? The bump skid does not eliminate the reason of the scrapes. It looks good. It might help protect the bottom a small amount but this is offset by increasing scrapping since there is less ground clearance.
    This is why you should get the suspension set up properly first; then, if you want to add a bump skid (for the looks) you can.
    Jerry
    Oct 2013
    Pottstown, PA
    Default Yep
    That's what I've always thought, but so many people love their bumpskid that I've been hesitant to "argue" about it. But now that you've already done that, I'm just gonna agree.
    The way I resolved the issue was to add BajaRon's shock adjusters to lift the front end, stop the porpoising, and smooth out the ride. My rubber padded bumper trim accent piece from Value Accessories (descried in post #6 above), was for the "good looks", and for those times I accidentally bump the nose - like getting too close to a curb when parking.
    If Ron had not come out with those shock adjusters, I'd have gone to Elka shocks. But fortunately he did, and that saved me a bunch of money.
    Also, it's worth noting that for those with early 2013 RT's who's shocks are too soft, BRP will replace your shocks if your dealer asks them to. When they first came out with the new non-adjustable shock, it was a sub-standard design. They fixed that half way through the model year, and then for 2014 they beefed up the front shock springs just a bit.
    Rob
    2013 RT Limited
    Apr 2015
    Boulder City NV
    cruzr Joe
    Thank you very much.
    Apr 2015
    Boulder City NV
    Default Solution
    My solution for the front end of my Spyder. Found some door edge trim at Pep Boys for $3.00 What do you think?
    Jun 2015
    North Bay, Ontario CANADA
    Quote Originally Posted by robmorg View Post
    If you decide to go with bellypan protection, just to let you know, I first tried a product similar to yours on my 2015 Spyder RT but was still getting damage to the stock plastic plate below the frunk, and the plastics underneath, so I too went with a Spyderpops Bumpskid. The ground clearance (stock) is not great on the Spyders and I think the Bumpskid is one of the best products I have added to my Spyder!
    I also added his preload adjusters, and added just enough, to bring the ground clearance up front back to stock.
    The Bumpskid ties all of the bodywork together in a much more secure fashion, and the added preload adjustment helps with the handling...
    A Win-Win situation!
    Nov 2012
    North Las Vegas, NV
    Roadster Renovations has spring stiffeners as well.http://dochumphreys.wix.com/roadster#!products/cdk6
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
