Resistor ...
I've installed LED accent lights all over my Spyder RT-S and recently, when I added MORE lights on the front and back, when I press my brake while the radio is on, the radio goes to static. How can I fix this? Has anyone else ever experienced this?
Getting ready to do this myself the day after tomorrow. Not being no expert by far, but I need to ask you, did you put a fusebox between this and your Cambus Electrical System? Or did you wire this directly into your Bike?
did you put something on the brake circuit
![Quote](images/misc/quote_icon.png) Originally Posted by Dikicep9
I have the LED'S on my front fenders( amber) & red( facing driver) & red on the side of saddlebags, I have a 2014RTS-SE6 and I get static when my radio is on. I have the same problem. Where did you buy your LED'S from?
Sent pm. Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
I have the fender LEDs, wired to be running lites and turn signals, and the CD brake lights with a modulator. I also just added 2 20W LED spots. The 20Ws are wired directly to the battery. No static at all
I had the same problem see
http://www.spyderlovers.com/forums/s...SB-power-ports
I posted an update on how my problem was solved
Hope this helps
Eddie Sheppard
Poole Dorset UK
Get a Spyder - See the World
![](signaturepics/sigpic6047_5.gif)
I hate to say this, but could this "Stray Electricity" be leaking out of a poorly insulated connection?
Ozzie Ozzie Ozzie
I've posted in eddieshep's thread, but I guess it won't hurt to post here too....
Are you sure this static wasn't happening before you added any farkles? My RT farts static thru the radio whenever the brakes are applied & has done since new (just over 15,000 kms ago now) but only when the radio is tuned to an AM station!! I've searched for poor connections & dodgy earths, fitted some ferrite cores, added a few 'extra' earth straps, changed all the brake light globes, & even checked the brake pedal switch for loose or frayed wiring etc.... but no; & it still makes rude static noises whenever I apply the brakes while the radio is on an AM station....
I had decided the bike just didn't like my choice of AM radio stations until I carried a UHF/VHF handheld radio on a recent trip, & it too belched static with every brake application!! So there's definitely something radiating when the brake pedal is pressed, & I don't have any LED's or other electrical mods/additions (yet....)
If you have static in the radio, I'd suggest applying the brakes when the Spyder isn't moving. Do you still hear the static ?? If not, then it's just static electricity generated by the friction of the pads and the rotor.
Ozzie Ozzie Ozzie
I read about 3 months ago or so that a guy had the same issue. It was the unshielded wiring for the HMT brake light running up to the trunk lid passing by the antenna block. He moved the wiring to the other side of the bike and it solved it.
Remember unshielded wiring always radiates EMF as current passes through it. I am sure this is what is happening.
Bob
It's strange that I happened on this thread. My wife was telling me this afternoon that she was getting static on her RTS radio when she brakes, on an FM station. Been reading the answers.The antenna cable is shielded to prevent external interference. but I'm not sure if it has a drain wire. Usually, only high power shielded cable has a drain wire. It would seem that something in the brake circuit is causing interference to the radio signal. That could be the brake light switch, the cruise control cut out switch and possibly an HMT. But, there are those who don't have an HMT and still have the static. So here's what I would do. Start disconnecting one switch at a time. You won't have easy access to the cruise cut out so just make sure the cruise control is off at the handlebar switch. If you have a HMT, disconnect it in turn. You won't need the engine running since the brake light function works off the battery except for the cruise function. If neither of these eliminates the static, then there is another problem. Static from brake pads is a non issue since if there is any, it would dissipate through the frame and the static happens even when the Spyder isn't moving. Just my 2 cents worth.
Ozzie Ozzie Ozzie
Think ground
For whatever odd reason, everything on the Can-Am seems to be grounded to the gas tank. Since you asked, consider installing a 14 gauge stranded ground wire between the antenna ground lug and the ground lug on the right rear of the gas tank. This will give the radio a unified ground and hopefully eliminate your static.
