Trailering the RT
I trailered the RT about 215 miles this week on a 7'x 14' utility trailer and I had to use ramps and it was a little awkward to load and tie down. I can make it a little easier to tie down but there is no way around the ramps unless I put a 4' tall fold down ramp on the back. I'm thinking of making a low, light weight tilt trailer using 3 pieces of channel for the tires to roll in. We have a local shop with a brake that could make the channel for me out of 1/8 sheet. I could fab them up out of 2x2 angle but that is time consuming and heavy. I know that we will be pulling the RT often behind our truck camper so a dedicated trailer makes sense. Anyone have some pics of a good design?
Now that I look at yours, Marie, making it low with a flat bed is a really good idea. Changing plans now.
Trailering the RT
![Quote](images/misc/quote_icon.png) Originally Posted by SailnDive
Ironhorsetrailers.com
I use the "ProLine" aluminum enclosed, has 5 rails in the floor for infinite tiedown movement, security. 1100 lbs and easy to move by hand as nbeeded. Check www.NHtrailers.com for a great selection and Tom is great to work with. If you want or need it, he cn make it work for you
SpydermanCT
2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
Drop tail trailers look like not to much of a hassle loading a
I have a 12ft dove tail works perfectly
Sent from my XT1060 using Tapatalk
